Export image from select objects Drawing Inventor 2020 -addin
Message 1 of 12
HI All
I would need your help on the export image from Inventor drawing 2d.
We are want to write add-in that end-user can select the object from drawing 2D in Inverter than Click button Export.
C# will export the object from 2D drawing to image save to somewhere in the file server.
Please help me if you are professional on that 🙂 A thousand.
One guy have done it in AutoCAD but now we move AutoCAD to inventor we need to migrate this function to inventor too
Annotation 2019-05-08 114913.png thanks
Replies (11)
Message 2 of 12
bradeneuropeArthur
Do you like to export the complete drawing as image or only the selection in the drawing?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
HI
Thank you for the reply.
I only want a selection.
Message 4 of 12
bradeneuropeArthur
That is more difficult.
The other option (Complete Drawing) is easier, so I need to take a deeper look at it and do some investigation.
I will reply when I have something.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
Thank you for your reply. I am looking forward to hear from you 🙂
Message 6 of 12
bradeneuropeArthur
Does this help you alreadt?
Public Sub SaveAsBmp()
    ' Get the active view.
    Dim oView As View
    Set oView = ThisApplication.ActiveView
 'Create a new NameValueMap Object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap '.TransientObjects.CreateNameValueMap
    oOptions.Value("TransparentBackground") = True 'True
    oOptions.Value("OnlyShowActiveComponentsForIn-PlaceEditing") = True
    oOptions.Value("OnlyShowActiveComponentsForInPlaceEditing") = True
    'oView.Fit
    Call oView.SaveAsBitmapWithOptions("C:\Temp\TestB2.bmp", 0, 0, oOptions)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
HI ,
I have searched then see that. But I don't know how to convert it into C# do you have any idea about that?
I stay at this step. Sorry I just new dev don't have experience.
Message 8 of 12
bradeneuropeArthur
I could create an add in for it, but only with VB.net!
Please let me know what you prefer..
regards,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Okay. If that the only choice could you please give me the full source code of add-in
I need to do a lost customizes after export photo 🙂
Thank you so much!!
Message 10 of 12
bradeneuropeArthur
The easiest and quickest way for this moment is to use a VBA macro in inventor.
With this you can already start today, and you don't have to wait.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
thanks. I don't refer to use VBA. Macro.
C# will be more professional  and structure than Macro
If you know want code can export pictures from inventor 2020 from C# please share me! thanks
Message 12 of 12
bradeneuropeArthur
The code for Vb.net is above.
For C# I don't have.
For the Vb.net add in you have to wait, or......
You need to provide me an vb.net add in where  I only have to add the specific code in it for you.
This means wou need to share an add-in with a toolbar for the ribbon and a button event.
Than I paste my code in it and that's it.
VBA is at least very easy and you don't have to wait till the add-in template is ready form your side.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
