Ilogic split a string
Message 1 of 9
Goodday,
I am searching for a way to split strings. Where:
Dim Separators() As Char = {";"}
Doesnt seem to work at my code.
As you see in the code the separator is-> ;
for example, if the string is 1;2, it must be separated into 1 and 2 given to 2 parameters,
so spot1 -> "1" and spot2 -> "2"
This also applies to, for example, 4;6;13 in 4, 6 and 13 given to 3 parameters, etc.
I hope i can find the solution im looking for over here!
Kind Regards,
Thomas
Replies (8)
Message 2 of 9
Sergio.D.Suárez
Hi Thomas, this should be the snippet you use to split the string.
Sentence = "1;2;3;4;5"
Words = Sentence.Split(Separators)
i = 0
For Each wrd In Words
MessageBox.Show("Word Index #" & i & " = " & Words(i))
i=i+1
Next
and for your specific case you could use
Sentence = "10;20;3;4;5"
spot1 = Words(0)
spot2 = Words(1)
Parameter.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
Where spot1 and spot2 are your user parameters to redefine.
I hope this helps solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 9
Thank you Sergio!
It worked did work, i changed it a bit to this;
Sentence = StringParameter
If Sentence = "1;1" Then
spot1 = Words(0)
spot2 = Words(1)
Else If Sentence = "1;5;7" Then
spot1 = Words(0)
spot2 = Words(1)
spot3 = Words(2)
InventorVb.DocumentUpdate()
Message 4 of 9
Sergio.D.Suárez
I'm glad you solved it. The fragment is just an update
 so I usually place it at the end of the code, it is not necessary to repeat it many times, you can eliminate those that are higher and leave only the last one. regards
Mechanical Designer
Message 5 of 9
LSKELLY
Hi Sergio
Thanks. This code has worked well for me but I find only one frustrating quirk with it. If I try to split on line breaks it splits it so that each split segment is preceded by a line break rather than deleting the splitting character as it did with the semi-colons. The modified code below will illustrate the problem:
Dim Separators() As Char = {";",vbCrLf} Sentence = "1" & vbCrLf & "2" & vbCrLf & "3" & vbCrLf & "4" & vbCrLf & "5"
i = 0
i=i+1
Next
Do you have any idea how to elegantly work around this or prevent it?
Message 6 of 9
Curtis_W
Hi @LSKELLY
I think this should work for you:
Words = Sentence.Split(vbCrLf)
	'strip out carraige returns & linefeeds
	wrd = wrd.Replace(vbCr, "").Replace(vbLf, "")
	MessageBox.Show("Word Index #" & i & " = " & wrd)
Next
Also just as a reminder, you can search and ask programming questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
(I've asked the moderators that this topic be moved to that forum to help in the future)
I hope this helps.
Curtis
Message 7 of 9
LSKELLY
Excellent! Thanks Curtis!
Kicking myself right now.
Message 8 of 9
Jesse_Glaze
Hello! I'm just curious about something.. if I have multiple separators in a single string, can this method still work? How would the "Dim Separators() As Char..." line be written for my example below?
Sentence = "XX.YY.ZZZZ-R0 PROJECT DESCRIPTION"
Separators = ".", "-", " "
Result:
Words(0) = XX
Words(1) = YY
Words(2) = ZZZZ
Words(3) = R0
Words(4) = PROJECT
Words(5) = DESCRIPTION
Message 9 of 9
WCrihfield
Hi @Jesse_Glaze.  Below is an example code like what you just described.  We could have used a 'For...Next' loop to show each 'word' in a MessageBox or MsgBox, but I just put it all in one big one, to present it the way you have it laid out above.
Dim Sentence As String = "XX.YY.ZZZZ-R0 PROJECT DESCRIPTION"
Dim Separators() As Char = {".", "-", " " }
Dim Words() As String = Sentence.Split(Separators)
Dim Word1 As String = Words(0)
Dim Word2 As String = Words(1)
Dim Word3 As String = Words(2)
Dim Word4 As String = Words(3)
Dim Word5 As String = Words(4)
Dim Word6 As String = Words(5)
MsgBox("Word1 = " & Word1 & _
vbCrLf & "Word2 = " & Word2 & _
vbCrLf & "Word3 = " & Word3 & _
vbCrLf & "Word4 = " & Word4 & _
vbCrLf & "Word5 = " & Word5 & _
vbCrLf & "Word6 = " & Word6, vbInformation, "Sentence Split Into Words")
Here is another version of the same, but using shorter report code at end.
Dim Words() As String = Sentence.Split({".", "-", " " },StringSplitOptions.RemoveEmptyEntries)
Dim sResults As String
For i As Integer = 0 To Words.Length - 1
	sResults &= "Word " & i & " = " & Words(i) & vbCrLf
Next
MsgBox(sResults, vbInformation, "Sentence Split Into Words")
Wesley Crihfield
(Not an Autodesk Employee)
