Excel formatting
Excel formatting
chendersonCRKPU
Excel formatting
chendersonCRKPU
I'd like to tidy up an excel worksheet using the API.
So far I've only used AutoFit on the column widths, but I'd like to center align certain columns, apply a border around the full range of used cells, bold the headings and apply a filter to the first row.
Can someone point me to where I can find the API for these things? Or a similar example
This is what I've got so far:
excelApp = CreateObject("Excel.Application")
excelApp.Visible = True
excelApp.DisplayAlerts = False
wb = excelApp.Workbooks.Open(oPATH + "BOM-PartsOnly.xlsx")
xlws = wb.Worksheets(1)
excelApp.Columns.AutoFit
excelApp = Nothing
bradeneuropeArthur
Use excel macros to read what the coding is for your options. I mean record your macro in excel and copy this to your code.
You understand?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
MechMachineMan
Yo check the links in my signature. MSDN is great.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
chendersonCRKPU
Thanks for your suggestions. I've tried both the record macro and the resources in your links. Both produced something which looks like it should work but I keep receiving this error on the red line below:
Unable to set the HorizontalAlignment property of the Range class
Call ReorderXLBOM()
excelApp.Rows("1:1").Select
excelApp.Selection.Font.Bold = True
excelApp.Selection.AutoFilter
xlws.Columns("A:A").HorizontalAlignment = xlCenter
I have also tried this (as per recorded excel macro) instead of that line but get the same error:
excelApp.Columns("A:A").Select
With excelApp.Selection
End With
I'm running this from iLogic environment directly after using BOMView.Export
MechMachineMan
Google: "horizontalalignment enum"
Why? You are setting a property using text - ergo, using an enum.
What the results of google returns:
https://msdn.microsoft.com/en-us/vba/excel-vba/articles/xlhalign-enumeration-excel
What this means for your code:
xlws.Columns("A:A").HorizontalAlignment = xlHAlignCenter
OR
xlws.Columns("A:A").HorizontalAlignment = xlHAlign.xlHAlignCenter
OR
xlws.Columns("A:A").HorizontalAlignment = -4108
If none of those lines work, either:
1. I found the wrong enum
2. Some spelling is wrong in the line
3. One of the members is not valid for the object it's called on, or
4. The Columns range is not a valid object to run the horizontalalignment command on.
Justin K
chendersonCRKPU
Imports Microsoft.Office.Interop.Excel.Constants
 Adding this statement solved it.
I only had
