Events viewer
Events viewer
Message 1 of 18
Events viewer
  • Where is Event viewer located in Inventor 2020, I am running Windows 10, user and dev tools are already installed but in see nothing related in sdk folder
Replies (17)
Message 2 of 18
WCrihfield
Was it an example AddIn provided by Autodesk in your previous install of Inventor?
Was it located in that SDK folder within your previous Inventor installation directory?
Or are you looking for a way to view events using either iLogic, or VBA?
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 18
I never used it in the previous version, I would have to check if it is in
the older versions sdk folder, just don't wanna run into compatibility
issues if I use the older event viewer with latest inventor version, but
yeah I would like to use it to listen to inventor events for ilogic/vb. I
have Visual studio community 2019 installed
Message 4 of 18
WCrihfield
I too have Vidual Studio Community 2019 installed. I got the User tools installed, but could never get the Dev Tools to install.  Every time I tried to install it, the installer kept saying it couldn't find Visial Studio, for some reason.
So, I can't direct you to the AddIn, but there are ways to work with events within the code environment.
I took the following screen shots of the drop down at the cursor within the iLogic Rule Editor screen.
You can experiment with these if you want.
Wesley Crihfield
Message 5 of 18
I would like to know when those events happen though. Idk if I am making sense, like seeing some debug logs to know which event happens when I click something in the UI
Message 6 of 18
JelteDeJong
I did't know there is (or used to be) an eventviewer from Autodesk. As part of an other project i made a very simple eventviewer. you can have a look at it:
https://github.com/hjalte79/ILogicRuleTester
(in the solution start the InventorEventTester)
Jelte de Jong
Blog: hjalte.nl - github.com
Message 7 of 18
bradeneuropeArthur
Are you seaching for the eventwatcher?
This is located in the SDK folder of inventor.
Found under:
C:\Users\Public\Documents\Autodesk\Inventor 20xx\SDK\DeveloperTools\Tools\EventWatcher\bin\Release\E...
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 8 of 18
Does not seem to be there in Iv 2020
Message 9 of 18
bradeneuropeArthur
Is the folder there?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 18
I don't even have the Tools folder inside the devtools folder
Message 11 of 18
bradeneuropeArthur
Do you have these files:
C:\Users\Public\Documents\Autodesk\Inventor 2020\SDK\usertools.msi
C:\Users\Public\Documents\Autodesk\Inventor 2020\SDK\developertools.msi
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 18
Yes I have them both, DevTools folder only has VBAddinTemplates and VCSAddinTemplates folders inside it
Message 13 of 18
bradeneuropeArthur
Do you have the msi files from the pevious post?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 18
Yes both files are there, there the ones I used for the installation
Message 15 of 18
bradeneuropeArthur
I need to take a look tomorrow for the 2020 installation.
I will inform you then, ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 18
No worries buddy
Message 17 of 18
bradeneuropeArthur
I have taken a quick look for you
for 2020 it is there with my setup:
What version of visual studio do you have installed?
Can you reinstall the MSI files again?
Let met know the reuslt.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 18
I found the awnser on another thread, I had visual studio 2019 installed, I installed 2017 and réinstalle the msi files, everything works fine now
