Document iRule to change external iRule Directory
Short story shorter, I have a setup template for many users at my office. It does all sorts of things, except the last thing I need it to do. I need a iLogic file tied to the document, where on open, it sets the External ilogic path to our networked location. This will be on open, for new users. If I can do this some other way, tied to this document, that will work too. This only has to be done once for each new user, or new installation. Setting the path manually for 60+ employees is kind of a pain.
Curtis_Waguespack
Hi @Anonymous
If I understand correctly, you are wanting to set the iLogic Configuration path with a rule?
here are a couple examples.
I hope this helps.
Curtis
'set one folder
Dim sList(0) As String
sList(0) = "C:\TEMP\Test\"
On Error Resume Next
iLogicVb.Automation.FileOptions.ExternalRuleDirectories = sList
sets multiple folders
Dim sList(2) As String
sList(1) = "C:\TEMP\Test\Part Rules\"
sList(2) = "C:\TEMP\Test\Drawing Rules\"
Curtis_Waguespack
@Anonymous wrote:
...Setting the path manually for 60+ employees is kind of a pain.
I should point out though that in more recent versions of Inventor, you can add this path(s) to the deployment image for new installs... I don't know when they added this, but it's probably something to look into as well
I hope this helps.
Curtis
Yes, this is exactly what I was looking for. Thank you
