Format Specific Exported Parameters from Assembly Level
DewayneH
DewayneH
I need to format the Thickness, Width, and Length parameters on a group of parts from the assembly level.
I know this has been done, and I found what I though were many solutions, none of which worked. At least I was able to screw it up. I'm finally at a point it looks like the rule is running, but nothing is changing.
I need to verify the rule is running only on parts that are modifiable. I'd also like the rule to run if is executed in a part file.
I've attached my latest failure.
Dewayne
Inventor Pro 2023
Vault Pro 2023
bradeneuropeArthur
What would you exactly like to do?
Could you explain it step by step?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
J-Camper
I believe this is working as you want, not too different from what you posted:
Sub Main
If ThisApplication.ActiveDocument.DocumentType = kPartDocumentObject Or ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then Else Exit Sub
Dim openDoc As Document = ThisApplication.ActiveDocument
'Look at all of the files referenced in the open document
Dim docFile As Document
If openDoc.DocumentType = kPartDocumentObject
	Call Formatting(openDoc)
Else
	For Each docFile In openDoc.AllReferencedDocuments
		'look at only part files that are modifiable
    	        If docFile.DocumentType = kPartDocumentObject And docFile.IsModifiable = True
			Call Formatting(docFile)
	Next
iLogicVb.UpdateWhenDone = True
End Sub
Sub Formatting(oDoc As PartDocument)
	'For Thickness Parameter
	Try
		oThickness = oDoc.ComponentDefinition.Parameters.UserParameters.Item("Thickness")
	Catch
		oThickness = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Thickness", 1, "in")
	End Try
	oThickness.ExposedAsProperty = True
	If oThickness.Units = "mm"
		oFormat=oThickness.CustomPropertyFormat
		oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
		oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
		oFormat.Units = "mm"
		oFormat.ShowUnitsString = True
		oFormat.ShowLeadingZeros = False
		oFormat.ShowTrailingZeros = True
	Else If oThickness.Units = "in"
		oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
		oFormat.Units = "in"
		oFormat.ShowUnitsString = False
	'] For Thickness Parameter
	'For Width Parameter
	Try
		oWidth = oDoc.ComponentDefinition.Parameters.UserParameters.Item("Width")
	Catch
		oWidth = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Width", 15, "in")
	End Try
	oWidth.ExposedAsProperty = True
	If oWidth.Units = "mm"
		oFormat=oWidth.CustomPropertyFormat
	Else If oWidth.Units = "in"
	'] For Width Parameter
	'For Length Parameter
	Try
		oLength = oDoc.ComponentDefinition.Parameters.UserParameters.Item("Length")
	Catch
		oLength = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Length", 45, "in")
	End Try
	oLength.ExposedAsProperty = True
	If oLength.Units = "mm"
		oFormat=oLength.CustomPropertyFormat
	Else If oLength.Units = "in"
	'] For Length Parameter
	oDoc.Rebuild
End Sub
I put the formatting into a subroutine to make handling the different document types easier in the main routine.
DewayneH
The rule would format the exported Thickness, Width, and Length parameters based on the parameters units, "in" or "mm".
For example:
If oThickness.Units = "mm" Then
                        Else If oThickness.Units = "in"  Then
If the rule runs in a part file the parameters would be formatted as shown based on the units.
If the rule runs in an assembly file, the parameters in all the parts would be formatted.
If the part is modifiable.
Dewayne
Inventor Pro 2023
Vault Pro 2023
DewayneH
That is almost exactly what I need.
The thing I didn't account for is, in some files the parameters may not be user parameters. Sometimes they can be model parameters. In those cases the rule recreates the parameter as a user parameter and the intended parameter doesn't get formatted.
For example if "Thickness" is a model parameter it won't be formatted, and "Thickness_1" will be created and formatted as a user parameter.
How can it be written to format the existing model parameter and not recreate it?
Dewayne
Inventor Pro 2023
Vault Pro 2023
J-Camper
You should be able to change the Trys to be less specific and look through all Parameters instead of all User Parameters:
Sub Main
Else
	Next
End Sub
	Try
		oThickness = oDoc.ComponentDefinition.Parameters.Item("Thickness")
	Catch
	End Try
	Try
		oWidth = oDoc.ComponentDefinition.Parameters.Item("Width")
	Catch
	End Try
	Try
		oLength = oDoc.ComponentDefinition.Parameters.Item("Length")
	Catch
	End Try
	oDoc.Rebuild
End Sub
DewayneH
That did it. Works like a charm.
Thanks for the help.
Dewayne
Inventor Pro 2023
Vault Pro 2023
