Ground Constraint
Ground Constraint
Message 1 of 10
Ground Constraint
I get an error when creating a ground constraint in a sketch block. I don't know what the problem is.
Here is the code:
Dim oBlockDef As SketchBlockDefinition
Dim oPointCenter As SketchEntity
oObject = ThisApplication.ActiveEditObject
If oObject.Type = ObjectTypeEnum.kSketchBlockDefinitionObject Then
oBlockDef = ThisApplication.ActiveEditObject
opoint=ThisApplication.TransientGeometry.CreatePoint2d(0,0)
oPointCenter=oBlockDef.SketchPoints.add(opoint,True)
' Here is the errror
oBlockDef.GeometricConstraints.AddGround(opointCenter)
Replies (9)
Message 2 of 10
WCrihfield
Try it this way.
Dim oObject As Object = ThisApplication.ActiveEditObject
If TypeOf oObject Is SketchBlockDefinition Then
      Dim oBlockDef As SketchBlockDefinition = ThisApplication.ActiveEditObject
      Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0,0)
      Dim oPointCenter As SketchPoint = oBlockDef.SketchPoints.Add(oPoint,True)
      oBlockDef.GeometricConstraints.AddGround(oPointCenter)
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 10
Nope i still get the error.
Hhere is the situation and error:
Message 4 of 10
J-Camper
This is weird behavior, I tried it in a regular sketch and it works perfect:
Sub Main
If ThisApplication.ActiveDocumentType <> kPartDocumentObject Then MessageBox.Show("This rule only works in Part files.", "Wrong Document type") : Exit Sub
Dim oBlock As Sketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Select a Sketch") : If IsNothing(oBlock) Then Exit Sub
'Enter Block Editor
oBlock.Edit
Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
oPointCenter = oBlock.SketchPoints.Add(oPoint, True)
Try
	oBlock.GeometricConstraints.AddGround(oPointCenter)
Catch
	MessageBox.Show("Failed to make constraint.", "Error") : oPointCenter.Delete
End Try
oBlock.ExitEdit
End Sub
But then defining oBlock as a SketchBlockDefinition, it won't work:
Sub Main
Dim oBlock As SketchBlockDefinition = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchBlockDefinitionFilter, "Select a Sketch Block") : If IsNothing(oBlock) Then Exit Sub
'Enter Block Editor
oBlock.Edit
Try
Catch
End Try
oBlock.ExitEdit
End Sub
Seems like this might be a bug?  It should work in the SketchBlockDefinition context based on the documentation found in the help file
I did find a possible work around by creating your geometry in a sketch and use the CopyContentsTo method into a new block:
Sub Main
'Enter Block Editor
oBlock.Edit
Try
Catch
End Try
oBlock.ExitEdit
Dim newBlock As SketchBlockDefinition
oBlock.CopyContentsTo(ThisApplication.ActiveDocument.ComponentDefinition.SketchBlockDefinitions.Add("new_Block"))End Sub
Message 5 of 10
Yeah i think it is also a bug
Message 6 of 10
It seems i can't add any constraints via ilogic when in sketchblockdefinition. Is this a bug?
Message 7 of 10
HideoYamada
I got a similar issue today and found this thread.
Has someone solved or found workaround?
I use .net API and c#.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 8 of 10
J-Camper
@HideoYamada
In the case of creating new sketch blocks, I posted a workaround where you build you geometry and constraints in a sketch and then CopyContentsTo a new sketch block.
In the case of modifying existing sketch blocks or creating them directly as sketch blocks, I have not found anything.
Message 9 of 10
HideoYamada
Hello @J-Camper
Thank you for replaying.
I'm waiting for Autodesk to fix this issue.  ( ; _ ; )
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 10 of 10
l.orzechowski
I'm struggling with same thing. Any news from Autodesk regarding that?
