Error only being caught on the first instance in a for loop? VBA
I'm having some trouble with an error that is occurring in part of my code. I don't know a great deal about error handling but I can't see why what I have done isn't working.
I'm using a VBA macro to find which faces have threads on, it works for all the threaded faces but produces an error if there isn't a thread there. This is fine as long as the error can be dealt with and doesn't stop the macro.
Here's the main part of the code:
'oAlignedFaceColl is a collection of cylindrical faces
   For i = 1 To oAlignedFaceColl.Count
Dim oThreadInfos As ObjectCollection Set oThreadInfos = oAlignedFaceColl(i).ThreadInfos On Error GoTo NextStep Set oThreadInfo = oAlignedFaceColl(i).ThreadInfos(1) Debug.Print Err.Number, "error number" NextStep: Next
The first error that's found does go to the line NextStep however the second time
MechMachineMan
You have half a post; seems to have been cut off.
However, it may be an error because you don't handle the error; there should be a resume statement somewhere, or a Err.Clear somewhere (I think). This alternative code below should also work.
        On Error Resume Next
  Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Apologies for that, I didn't realise only half was posted! Unfortunately I need the goto ( I skipped an unimportant chuck of code). I also tried using an err.clear and on error resume next in varying places with no success.
I have since found an alternative way of doing what I want but am still curious for the reason behind it not originally working if you have any other suggestions?
ruthsteed
In the "error handling" section (at the label "NextStep:" you need to have a "Resume" statement to return to the loop body correctly. This can be either a simple "Resume Next" if the code can reasonably continue after the error, or a "Resume AfterErrorLabel" where "AfterErrorLabel" is another location in your code.
For example, to just return to the Debug.Print (which is unaffected by the error line before):
   For i = 1 To oAlignedFaceColl.count
   Next
NextStep:
       Resume Next
You can find more information on this by Googling "vba error handling in loop", but it's probably easier to not bother with the error handling at all in this case. The real problem is that oAlignedFaceColl(i).ThreadInfos is Nothing. When you try to access anything inside it, it fails. It would be simpler to just check that oThreadInfos is set.
Something like this, doesn't require any additional On Error directives:
       If Not oThreadInfos Is Nothing Then
           Debug.Print oThreadInfos.count; " threadinfos"
           If oThreadInfos.count > 0 Then
               Debug.Print oThreadInfos(1).CustomThreadDesignation
       Else
           Debug.Print "No threadinfos"
   Next
Ruth Steed
Inventor Development Team
Autodesk, Inc.
