Exporting .ipt to .igs with custom filename
PDX_Matt
PDX_Matt
I am trying to tweak the iLogic Snippet for "Save As IGES File" so that it will save the file to a new folder called "IGES" and have the file name be the iProperty "Part Number".  I can add "iProperties.Value("Project", "Part Number")" at the file name part, but it still has the original name that i have to go back and delete.  I just want the file named as the Part Number and put in a new folder.
Help!
Here is the current code i have:
' Get the IGES translator Add-In.
Dim oIGESTranslator As TranslatorAddIn
oIGESTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F44-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oIGESTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
   ' Set geometry type for wireframe.
   ' 0 = Surfaces, 1 = Solids, 2 = Wireframe
   oOptions.Value("GeometryType") = 1
   ' To set other translator values:
   ' oOptions.Value("SolidFaceType") = n
   ' 0 = NURBS, 1 = Analytic
   ' oOptions.Value("SurfaceType") = n
   ' 0 = 143(Bounded), 1 = 144(Trimmed)
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oData As DataMedium
oData = ThisApplication.TransientObjects.CreateDataMedium
oData.FileName = ThisDoc.PathAndFileName(False) & iProperties.Value("Project", "Part Number") & ".igs"
oIGESTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
MechMachineMan
oData.FileName = ThisDoc.Path & "\" & iProperties.Value("Project", "Part Number") & ".igs"
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @PDX_Matt,
Change the path of oData.FileName to following line.
oData.FileName = ThisDoc.Path & "\IGES\" & iProperties.Value("Project", "Part Number") & ".igs"
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
PDX_Matt
Thank you for the help!!
