No simulation tab on my inventor pro 2018
I'm trying to run the CFD  manifold tutorial. First step is to open the .iam in inventor. 2nd step is to launch the model via the simulation tab and active model.  I do not have a simulation tab. Where is it?
Cheers
MechMachineMan
Check that the Simulation Add-In is loaded.
Tools > Options > Add-ins
Scroll down until you find whatever add-in sounds like it pertains to the Simulation. Ensure that the boxes are both checked for "Load Automatically" And "Loaded/Unloaded".
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for the help,
I have 3 simulation add-ins and they are all automatic. I would have thought I'd have one for CFD...
[cid:image001.png@01D31CD9.AAF5E900]
salariua
You are missing a step or sequence. that screenshot refers to Simulation Mechanical and if you have that installed then follow >>this<< link to install the Inventor Plugin for it.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
If so please use the Accepted Solutions or Like button - Thank you!
