error code
error code
johan.degreef
Advisor Advisor
Message 1 of 42
error code
johan.degreef
I get a lot of these error codes lately, with this code. Does anyone sees where it comes from?
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Document.SaveAs(String FileName, Boolean SaveCopyAs)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Imports System.IO
GetInput :
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 000000)
If Six_Digit = "" Then
	Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
	If oFilename.Contains(Six_Digit) Then
		Dim oOptions As Inventor.NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
		sFilename = oFilename
		Exit For
Next
If sFilename = "" Then
	MessageBox.Show("No matching libary file found.", "iLogic")
	Return
iCounter = 0
'path from current file
oActiveAssemblyfolder = ThisDoc.Path & "\"
'path from current project file ( *.ipj)
oProjectfolder = _
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath & "\"
Dim oProject_Filenames() As String
oProject_Filenames = System.IO.Directory.GetFiles(oProjectfolder, _
'count existing project files
For Each oFilename As String In oProject_Filenames
		iCounter = iCounter + 1
Next
'increment counter
'find the postion of the last backslash in the path
FNamePos = InStrRev(sFilename, "\", - 1)
'get the file name with the file extension
oName = Right(sFilename, Len(sFilename) - FNamePos)
'get the file name (without extension)
ShortName = Left(oName, Len(oName) - 4)
'get extension
oExt = Right(oName, 4)
If iCounter < 10 Then
	iCounter = "00" + CStr(iCounter)
ElseIf iCounter < 100 Then
	iCounter = "0" + CStr(iCounter)
Else
	iCounter = CStr(iCounter)
oNewName = ShortName & "_" & iCounter
oPathandName = oActiveAssemblyfolder & oNewName & oExt
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
'oOcc.Grounded = False
'ThisDoc.Document.SelectSet.Select(oOcc)
'MessageBox.Show("New file created: " & vbLf & oPathandName, "iLogic")
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (41)
Message 2 of 42
JhoelForshav
Hi @johan.degreef
Usually when SaveAs fails for no apparent reason it's because inventor has a document with that file name in memory. You might have deleted the document in your file system but it's still kept in inventors memory.
Try this line:
ThisApplication.Documents.CloseAll(True)
And then run your code. It'll close all unreferenced documents in memory.
Message 3 of 42
bradeneuropeArthur
Hi @johan.degreef
Put some messageboxes in the code an take a look till where the codes runs!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 42
johan.degreef
@JhoelForshav
This did not help. Thanks anyway
Message 5 of 42
JhoelForshav
Ok...
Since you're using ThisDoc.Path, have you saved the document in which you run the rule? Otherwise that will not return a valid path.
Message 6 of 42
johan.degreef
@bradeneuropeArthur
thanks for the suggestion
After clicking OK on messagebox 6, the error appears. i do not see messagebox 7
Imports System.IO
GetInput :
	Return
GoTo GetInput
MessageBox.Show("Message1", "Title")
'hard code path
		Exit For
Next
	Return
MessageBox.Show("Message2", "Title")
iCounter = 0
oProjectfolder = _
Next
'increment counter
MessageBox.Show("Message3", "Title")
'get extension
MessageBox.Show("Message4", "Title")
Else
MessageBox.Show("Message5", "Title")
MessageBox.Show("Message6", "Title")
'save new document
oDoc.Close
MessageBox.Show("Message7", "Title")
'[ Place Component
MessageBox.Show("Message8", "Title")
' Create Matrix
MessageBox.Show("Message9", "Title")
Message 7 of 42
johan.degreef
@JhoelForshav
@JhoelForshav wrote:
Ok...
Yes
Message 8 of 42
JhoelForshav
Could you have a look at oPathAndName with a msgbox to make sure it returns a valid existing path and that the file doesn't already exist?
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
iCounter = 0
oProjectfolder = _
Next
'increment counter
'get extension
Else
MsgBox(oPathandName)
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 9 of 42
johan.degreef
@JhoelForshav
It returns:
If I check, that file DOES already exists, but why doesn't the search code DOESN'T finds it, after all these years of working flawlessly?
EDIT: After opening that part _025.ipt itself and resave it, it's get found. This part is there for days, it is not that i placed that just before.
Message 10 of 42
bradeneuropeArthur
Have you enabled "Show extension for known filetypes" in Explorer
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 42
johan.degreef
Yes...
Don't tell me that this is the cause 🙂
Message 12 of 42
JhoelForshav
Hi @johan.degreef
I'd say maybe your loop to set the iCounter variable isn't that stable. It only counts how many files are in the path containing the six digits and then assumes the number should be that +1. So If there would be 5 files numbered 1,2,3,4,6 you'd get this error.
It looks like your files ends with "_XXXX.ipt/iam" where XXXX is the number. I'd suggest looking at these numbers and take the highest value + 1 to make sure it's unique.
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
iCounter = 0
oProjectfolder = _
		Dim oFileNameSplit As String() = System.IO.Path.GetFileNameWithoutExtension(oFilename).Split("_")
		If CInt(oFilename.Length - 1) > iCounter Then iCounter = CInt(oFilename.Length - 1)
Next
'get extension
Else
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 13 of 42
johan.degreef
@JhoelForshav
You might be right, because at the time of the error, there were +-24 parts of "PIPE_200213_xxx.ipt" present in the project. It seems that the numbers are not counted in a row 001, 002, 003, but rather 001, 006, 007, 009 etc. with gaps.
It might be the case that during the project files were deleted, because they were not needed anymore.
When you say " It only counts how many files are in the path with containing the sig digits and then assumes the number should be that +1". i hope he count the files in the whole projectfolder - that was the intention at least.
The parts are saved in the folder where the assembly resides, so that can be all over the project.
If I ever wanted to correct this bit of code, i need to rely on you guys, because I have too less programming skills for that.
Maybe I should wait to see if it happens again after disabling "Show extension for known filetypes" in Explorer.
Message 14 of 42
JhoelForshav
@johan.degreef
Yes... Sloppy written text by me. But you get the idea and I think we might have found the problem then.
Does the code I posted work? 🙂
Message 15 of 42
johan.degreef
@JhoelForshav
Your code works, but I'll check if it works when I get the error again with my old code.
You did change this bit, right? he does look in all folders in the project right?
Next
Message 16 of 42
johan.degreef
@JhoelForshav
Sorry JhoelForshav, but I had the error again. With my code, and with your modified code. Again he came up with a number that already existed in my project and therefore failed to save it and place it in my assembly
@bradeneuropeArthur
The "file extention" setting was also disabled, but this not solve the problem
Message 17 of 42
JhoelForshav
@johan.degreef
Sorry! I really messed that one up for some reason! 😄
I meant to write it like this!
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
iCounter = 0
oProjectfolder = _
		If CInt(oFileNameSplit(oFileNameSplit.Length - 1)) > iCounter Then iCounter = CInt(oFileNameSplit(oFileNameSplit.Length - 1)) + 1
Next
'get extension
Else
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 18 of 42
johan.degreef
@JhoelForshav
with this code he makes this out of it: PIPE_200213_850002.ipt
no counter of 3 digits anymore...?
Message 19 of 42
JhoelForshav
@johan.degreef
This must work?
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
Dim iCounter As Integer = 0
oProjectfolder = _
Next
iCounter += 1
FNamePos = InStrRev(sFilename, "\", -1)
oName = Right(sFilename, Len(sFilename) -FNamePos)
ShortName = Left(oName, Len(oName) -4)
'get extension
oNewName = ShortName & "_" & iCounter.ToString("0000")
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oPathandName)
Now I format iCounter to four digits with iCounter.ToString("0000")
Message 20 of 42
johan.degreef
@JhoelForshav
No, it makes PIPE_200213_850003.ipt
Maybe we should replace the counter by a random generated code of +-20 digits? no duplicates then....
PIPE_200213_dK5p43Hes35rJ5Sxd63U.ipt
