error code
error code
johan.degreef
Advisor Advisor
Message 1 of 42
error code
johan.degreef
I get a lot of these error codes lately, with this code. Does anyone sees where it comes from?
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Document.SaveAs(String FileName, Boolean SaveCopyAs)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Imports System.IO
GetInput :
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 000000)
If Six_Digit = "" Then
	Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
	If oFilename.Contains(Six_Digit) Then
		Dim oOptions As Inventor.NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
		sFilename = oFilename
		Exit For
Next
If sFilename = "" Then
	MessageBox.Show("No matching libary file found.", "iLogic")
	Return
iCounter = 0
'path from current file
oActiveAssemblyfolder = ThisDoc.Path & "\"
'path from current project file ( *.ipj)
oProjectfolder = _
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath & "\"
Dim oProject_Filenames() As String
oProject_Filenames = System.IO.Directory.GetFiles(oProjectfolder, _
'count existing project files
For Each oFilename As String In oProject_Filenames
		iCounter = iCounter + 1
Next
'increment counter
'find the postion of the last backslash in the path
FNamePos = InStrRev(sFilename, "\", - 1)
'get the file name with the file extension
oName = Right(sFilename, Len(sFilename) - FNamePos)
'get the file name (without extension)
ShortName = Left(oName, Len(oName) - 4)
'get extension
oExt = Right(oName, 4)
If iCounter < 10 Then
	iCounter = "00" + CStr(iCounter)
ElseIf iCounter < 100 Then
	iCounter = "0" + CStr(iCounter)
Else
	iCounter = CStr(iCounter)
oNewName = ShortName & "_" & iCounter
oPathandName = oActiveAssemblyfolder & oNewName & oExt
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
'oOcc.Grounded = False
'ThisDoc.Document.SelectSet.Select(oOcc)
'MessageBox.Show("New file created: " & vbLf & oPathandName, "iLogic")
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (41)
Message 21 of 42
JhoelForshav
This is driving me crazy... where is the "85" part of the name coming from??
Message 22 of 42
johan.degreef
one of the last parts i inserted was PIPE_200213_085.ipt
Shall I send you my library?
Message 23 of 42
JhoelForshav
Ok....
So I see now that you only want three digits and I made it four. That is fixed in the code below.
What I cannot understand is why we don't get the "_" in the filename when we obviously add it!
Dim oNewName As String = ShortName & "_" & iCounter.ToString("000")
When I try it on my machine with random filepaths everything works as expected....
This code really should work 😞 At least it should add the "_"...
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
Dim iCounter As Integer = 0
Dim oActiveAssemblyfolder As String = ThisDoc.Path & "\"
Dim oProjectfolder As String = _
		Dim oFileNameSplit As String() = System.IO.Path.GetFileNameWithoutExtension(oFilename).Split("_")
		If CInt(oFileNameSplit(oFileNameSplit.Length - 1)) > iCounter Then iCounter = CInt(oFileNameSplit(oFileNameSplit.Length - 1))
Next
iCounter += 1
Dim FNamePos As Integer = InStrRev(sFilename, "\", -1)
Dim oName As String = Right(sFilename, Len(sFilename) -FNamePos)
Dim ShortName As String = Left(oName, Len(oName) -4)
'get extension
Dim oExt As String = Right(oName, 4)
Dim oPathandName As String = oActiveAssemblyfolder & oNewName & oExt
MsgBox(oPathandName)
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oPathandName)
Message 24 of 42
johan.degreef
@JhoelForshav
Maybe my bad because of the 85.... there was a part in my folders ..._850002.ipt I deleted both and now it seems to work OK. I will test a few days and let you know if all work.
Million times thanks for helpingme out here!
Message 25 of 42
JhoelForshav
@johan.degreef
That sounds like the problem😆
Hopefully it'll work as expected from now on 🙂
Message 26 of 42
johan.degreef
@JhoelForshav
Another issue popped up.
When I create a mirror in my assembly, the filenames get _MIR behind.
PIPE_200211_010_MIR.ipt
when this occurs I get the error below when trying to enter another 200211 pipe
System.InvalidCastException: De conversie van tekenreeks MIR1 naar type Integer is ongeldig. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
--- End of inner exception stack trace ---
at ThisRule.Main()
Message 27 of 42
JhoelForshav
@johan.degreef
I havn't tried the code myself but I think this should work then 🙂
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
		Dim oNumber As Integer
		If oFileNameSplit(oFileNameSplit.Length - 1) = "MIR" Then
			oNumber = CInt(oFileNameSplit(oFileNameSplit.Length - 2))
		Else
			oNumber = CInt(oFileNameSplit(oFileNameSplit.Length - 1))
		If oNumber > iCounter Then iCounter = oNumber
Next
iCounter += 1
'get extension
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 28 of 42
JhoelForshav
Maybe change:
To
If oFileNameSplit(oFileNameSplit.Length - 1).Contains("MIR") Then
Because in your error message it seems like it's "_MIR1" and not "_MIR"...
Message 29 of 42
johan.degreef
@JhoelForshav
Thank you It works,
but can't we better say if length of "oFilename is different from 15 characters" (PIPE_200211_000.ipt), because now it is MIR, but next time it could be something else. Now it is after, but next time it may be before "PIPE_200211_000"
Message 30 of 42
JhoelForshav
Like this? 🙂
GetInput :
	Return
GoTo GetInput
'hard code path
	Dim oFileNameNoExt As String = System.IO.Path.GetFileNameWithoutExtension(oFilename)
	If oFileNameNoExt.Contains(Six_Digit) AndAlso oFileNameNoExt.Length = 15 Then
		Exit For
Next
	Return
		Dim oFileNameSplit As String() = oFileNameNoExt.Split("_")
		Dim oNumber As Integer = CInt(oFileNameSplit(oFileNameSplit.Length - 1))
Next
iCounter += 1
'get extension
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 31 of 42
johan.degreef
I think so. it will grab more potential errors, no?
Message 32 of 42
JhoelForshav
Yes. You wouldn't get any error with the previous code though if the numbering was the last part of the filename. But if the last part of the filename wouldn't be the number and also not contain "MIR" it would throw an error.
Message 33 of 42
johan.degreef
@JhoelForshav
It seems to work quiet well - many thanks.
Would you be so kind to add a line so that the new part's iproperty "Part Number" = variable "Shortname" while saving it?
ex. Partnumber = PIPE_200213
Imports System.IO
GetInput :
	Return
GoTo GetInput
'hard code path
	If oFileNameNoExt.Contains(Six_Digit) AndAlso oFileNameNoExt.Length = 11 Then
		Exit For
Next
	Return
Next
iCounter += 1
'get extension
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 34 of 42
JhoelForshav
Sure 🙂
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
Next
iCounter += 1
'get extension
oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = ShortName
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 35 of 42
johan.degreef
Great Thank you!
Message 36 of 42
johan.degreef
@JhoelForshav
You want to know what woke me up this morning? the idea we could make the code much easier and also more performant? You already helped me big time, so no worries I it is not possible in your time.
What if we would skip the whole icounter code to look for parts already in the projectfolder and add 1 to the icounter to become a unique name?
Just append date and time to the library part and done.
PIPE_200213.ipt would than become PIPE_200213_20200828141136.ipt
syntax
PIPE_200213_<currentyear><currentmonth><currentday><current24hour><currentminute><currentsecond>
and done. Uniqueness garantied, without looping through all the parts in my project, no?
Message 37 of 42
JhoelForshav
I think this will be enough then 🙂
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
'get extension
Dim oNewName As String = ShortName & "_" & Now.Date.ToString
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 38 of 42
johan.degreef
On my side I get error
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Inventor._DocumentClass.SaveAs(String FileName, Boolean SaveCopyAs)
at ThisRule.Main()
Message 39 of 42
JhoelForshav
How about now?
GetInput :
	Return
GoTo GetInput
'hard code path
		Exit For
Next
	Return
'get extension
Dim oNewName As String = ShortName & "_" & Microsoft.VisualBasic.DateAndTime.Now.Date.ToString("yyyyMMddHHmmss")
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
Message 40 of 42
johan.degreef
@JhoelForshav
It works, but the result is PIPE_200213_20200828000000.ipt
Date is OK, but there's something wrong with the time
