Switching the style of a Balloon via Ilogic
hoeckesfeld
hoeckesfeld
Hi all,
I try to get a balloon in an idw to switch styles upon selecting it and pressing my shortcut.
I tried the following ilogic rule and many variations of it. What am I doing wrong, can somebody help?
Public Class switchPosStyle
	Public Sub Main
		Dim oDocument As DrawingDocument = ThisApplication.ActiveDocument
		If oDocument.DocumentType <> kDrawingDocumentObject Then
			Exit Sub
		Else If oDocument.SelectSet.Count <> 1 Then
			Exit Sub
		Else If Not TypeOf oDocument.SelectSet.Item(1) Is Balloon
			Exit Sub
		Else
			For Each styleItem As BalloonStyle In oDocument.StylesManager.BalloonStyles
				If styleItem.Name = ("StyleNameIwantToSwitchTo") Then
					oDocument.SelectSet.Item(1).Style = styleItem
			Next
	End Sub
End Class
The styles are definitly available in the idw.
Thank you!
R.Mabery
Something like this?
Dim oSelectSet As SelectSet
oSelectSet = oDocument.SelectSet
Dim oBalloon As Balloon
Dim oBalloonStyle As BalloonStyle
oBalloonStyle = oDocument.StylesManager.BalloonStyles.Item("New")
	Exit Sub
Else If oSelectSet.Count <> 1 Then
	Exit Sub
Else If Not TypeOf oSelectSet.Item(1) Is Balloon
	Exit Sub
Else
	oBalloon = oSelectSet.Item(1)
	oBalloon.Style = oBalloonStyle
Randy Mabery
Applications Expert
IMAGINiT Technologies
hoeckesfeld
Thanks, it works! But could you maybe explain my mistake? I don't see what i've done essentially different, except for not using SelectSet..
R.Mabery
Sure thing.  I believe that you were wanting to modify the style of a single balloon.  Your code was looking through the BalloonStyles in the Styles and Standards Editor and looking at their names.
What I presented is looking at the style of the currently selected balloon.
Maybe I missed what you were wanting to do?
Randy Mabery
Applications Expert
hoeckesfeld
No you are right, thats exactly what I want to do.
Yeah, I went through the style manager to find the style I want:
But don't I then assign that style to the style of the currently selected balloon?
R.Mabery
It doesn't know that your
is a Balloon and therefore doesn't understand the .Style property of it.
It's really the setting of the selected item to a Balloon that makes mine work.  I moved the additional stuff to the top just because that's my style of coding.  🙂
Randy Mabery
Applications Expert
hoeckesfeld
Ah alright. I thought once the Balloon Object is selected the .style property would "find it's way" so to speak. Thank you.
