Ilogic code correction
05:14 AM
Can someone help me solve this problem?
In the following ilogic code, I want to run the first part of the rule when I type Rec when the part is rectangular and when I type Cir, it runs the second part only. But it is not the case. It is only executing the else part of the ilogic.
If myparam = InputBox("Type 'Rec' if the part is rectangular or square or Type 'Cir' if the part is circular", "Shape Specification", "Type",Rec) Then extents_length = Measure.ExtentsLength extents_length = Round(extents_length) extents_width = Measure.ExtentsWidth extents_width=Round(extents_width) extents_thickness= Measure.ExtentsHeight iProperties.Value("Custom", "SPECIFICATIONS") = "PLATE " & extents_thickness & " THK " & extents_length & " x " & extents_width Else extents_length = Measure.ExtentsLength extents_length = Round(extents_length) extents_thickness = Measure.ExtentsWidth iProperties.Value("Custom", "SPECIFICATIONS") = "PLATE " & extents_thickness & " THK Ø " & extents_length End If
