Ilogic code correction
Can someone help me solve this problem?
In the following ilogic code, I want to run the first part of the rule when I type Rec when the part is rectangular and when I type Cir, it runs the second part only. But it is not the case. It is only executing the else part of the ilogic.
If myparam = InputBox("Type 'Rec' if the part is rectangular or square or Type 'Cir' if the part is circular", "Shape Specification", "Type",Rec) Then
	extents_length = Measure.ExtentsLength
		extents_length = Round(extents_length)
	extents_width = Measure.ExtentsWidth
		extents_width=Round(extents_width)
	extents_thickness= Measure.ExtentsHeight
	iProperties.Value("Custom", "SPECIFICATIONS") = "PLATE " & extents_thickness & " THK " & extents_length & " x " & extents_width
Else
	extents_thickness = Measure.ExtentsWidth
	iProperties.Value("Custom", "SPECIFICATIONS") = "PLATE " & extents_thickness & " THK Ø " & extents_length
End If
R.Mabery
It looks like your conditional statement is in the wrong place (at least it's one way of changing this).
If myparam = "Rec"
Else
End If
Get the myParam and then evaluate it.
Randy Mabery
Applications Expert
IMAGINiT Technologies
Thanks. I will try and let you know if it worked.
