DrawingPrintManager issue with DWG
ThomasRambach
Advisor Advisor
ThomasRambach
I have some code that I'm using in conjunction with the Vault Job Processor to print drawings to PDF. I need it to work for Inventor drawings as well as AutoCAD DWG from Inventor. I can get it to submit the AutoCAD DWG print and it looks ok, except the view only shows the bottom left corner of the drawing and not the whole drawing zoomed out. Not sure how to handle this. I've tried just saving to PDF, translating, printing to file. All have about the same results. I can print the DWG directly from Inventor manually without issues. Any ideas on how to proceed?
bradeneuropeArthur
Why not printing from vault with the jobprocessor?
Here you are able to print either with autocad or Inventor.
Vault has also included a mechanism to print files (Autocad and Inventor) to Pdf.
This can be automated at for example on State-Change..
No coding required for this
What version of Vault are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
ThomasRambach
@bradeneuropeArthurIunderstand that, our process is a little more complicated then the out of the box solutions.
