iLogic - rename iPart member and borwser node
Log0ut
Log0ut
What i have:
iPart.ChangeRow("iPartName:1", "meberName")
In browser, I need to change  iPartName:1 to meberName.
Ideas?
johnsonshiue
Hi! I don't think this is the right approach. iPart members are totally driven by iPart factory (author table). Any attempt to override this relationship can be problematic. You cannot manually do it. Nor would iLogic be able to help.
If you want to use iLogic, you should consider drive the parameters from the rules, not via iPart table. iParts are supposed to be library components for reuse purpose.
Many thanks!
Software Test Engineer
Log0ut
I try to be more clearly(my english and ilogic skills are poor):
I have ipart components in my assembly: iPart_member1:1; iPart_member1:2; iPart_member1:3 ...
Now i want to find and change all iPart_member1's to iPart_member2
Simple code be like that:
iPart.ChangeRow("iPart_member1:1", "iPart_member2.ipt")
iPart.ChangeRow("iPart_member1:2", "iPart_member2.ipt")
And so on
