Drawing view events, on create new sheet
basnederveen
basnederveen
Hi everyone
I was wondering if it is possible to create an event trigger that triggers when a new drawing sheet is created. If it is, how?
Kind regards
Bas
bradeneuropeArthur
Hi Bas,
Yes:
Private WithEvents oUINewDrawingView As UserInputEvents
Public Sub Activate(ByVal addInSiteObject123 As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
oUINewDrawingView = m_inventorApplication.ApplicationEvents
end sub
Private Sub UINewDrawingView_OnActivateCommand(CommandName As String, Context As Inventor.NameValueMap) Handles oUINewDrawingView.OnActivateCommand
            'MsgBox(CommandName)
            If CommandName = "DrawingNewSheetCtxCmd" Then
'Your code here
end if
end sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
basnederveen
Thanks again!
Could you break down some of this information for me? It doesn't work if I just copy and paste it into my project, and I would like a better understanding of it anyways.
any help would be greatly appreciated.
basnederveen
You can use userinputevents.onactivatecommand with drawingnewsheet command. If you need to do stuff on the new sheet before it is activated probably applicationevents.onneweditobject.
Thank you. I'll try playing with those commands
antoniobaron
I know i'm a little bit late, but these commands and instructions are for vb.net, vba, and add-in programming. So they won't work for ilogic.
There are various tutorials on autodesk university regarding addin development.
Cheers
