export parameter in inventor to excel
Trying to export parameter list to excel with no links, just as a one time action.  Is there a way to do this?
Kim
tdant
 Click the "Manage" drop down under the Parameters button and select "Export to XML".
Then you can use a converter to make it an Excel file.
EDIT: Actually, Excel can import XMLs natively via the Developer tab, so you don't need a convertor.
JBerns
Due to errors in the XML file because of (Inventor?) formatting errors, I could not open the XML file with Excel. A serious error occurred and crashed Excel.
However, I was able to use this site https://json-csv.com/xml to convert the XML to CSV.
Next, I could open the CSV to discover parameter names, types, and values, including multi-value lists.
Hope this is helpful to others.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
I'm not sure how many parameters you have, but you could write them out using the standard Excel Snippets that come with Inventor
c1  = GoExcel.CellValue("filename.xls", "Sheet1", "A2")
c2 = GoExcel.CellValue("filename.xls", "Sheet1", "A3")
