(Drawing) Break or Crop with dimmension
- Mute
- Permalink
- Report
I have a drawing to make, which forces me to use either Break or Crop.
My problem is that the middle element of an Assembly is very long and it needs to be cut in order to precisely see the rest of this drawing. However I would like to control the position of this Break line, because the middle element is going to change it's length.
In Attachments you'll find a file (in both dwg and pdf) where you can see a simplified example. The interesting area is above Line Y and below Line X.
I used Break command, but I would like to have this line 50mm from a specific line (I don't see this possibile).
Other possibility is to use Crop command, but it is impossibile to have 2 Crops in one view. I tried to use 2 views with one Crop in each, but then I'm unable to put a dimension between this views (like ZZ dimension).
Do you have any solution?
