iLogic skip iProperty feild when it does not exit
schmidkeadam
schmidkeadam
ok I'm stumped...... What I am going for is to have Ilogic go out and sum my subassembly custom iproperties. The code that I have is able to go out and read the illogic if the iproperties exits but it gets an error when one of the subassemblies does not have the custom Iproperties. How do I change my code that if one of my subassemblies does not have custom iproperties, it will not error out?
SyntaxEditor Code Snippet
'- - - - - - - - - - - find or create custom iProperty - - - - - - - - - -
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
'--------------------------------------------------------------------------------- (Water Creation)
Dim propertyName1 As String = "Water (PSI)"
oCustomPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties")
Try
oProp = oCustomPropertySet.Item(propertyName1)
Catch
oCustomPropertySet.Add(0, propertyName1)
End Try
Next
'---------------------------------------------------------------------------------- (Voltage Creation)
Dim propertyName3 As String = "Voltage"
Try
oProp = oCustomPropertySet.Item(propertyName3)
Catch
oCustomPropertySet.Add(0, propertyName3)
End Try
'- - - - - - - - - - - Sum of the Custom iProperty - - - - - - - - - -
iProperties.Value("Custom", "Water (PSI)") = 0
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
xNumber = iProperties.Value("Custom", "Water (PSI)")
yNumber = iProperties.Value(oOccurrence.Name,"Custom", "Water (PSI)")
sumNumber =  xNumber + yNumber
iProperties.Value("Custom", "Water (PSI)") = sumNumber
Next
iProperties.Value("Custom", "Voltage") = 0
xNumber = iProperties.Value("Custom", "Voltage")
yNumber = iProperties.Value(oOccurrence.Name,"Custom", "Voltage")
iProperties.Value("Custom", "Voltage") = sumNumber
Next
'-------------------------------------- Message Box
Water = iProperties.Value("Custom", "Water (PSI)")
Voltage = iProperties.Value("Custom", "Voltage")
MessageBox.Show("Water = " & Water & vbLf &
"Voltage = " & Voltage & vbLf, " Summary ")
bradeneuropeArthur
hi,
Use in general an Empty string like this example:
oCustomPropertySet.Add("", propertyName1)
you are never sure what the value needs to be like a string or a double
or use this method:
oCustomPropertySet.Add("0", propertyName1)
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
