Dockable window does not resize
JelteDeJong
Mentor Mentor
Message 1 of 10
JelteDeJong
resizeNotWorking.pngIm creating an addin with a dockable window. It works fine but when the dockable window is floating it is not possible to rezise it anymore. (draging the edge does not work.)
i create the dockable window with the following code:
Form1 form = new Form1(inventor);
UserInterfaceManager uiMan = inventor.UserInterfaceManager;
docableWin = uiMan.DockableWindows.Add("###############", "###############", "###############");
docableWin.AddChild(form.Handle.ToInt64());
docableWin.Title = "SheetOverView";
docableWin.ShowTitleBar = true;
docableWin.DisabledDockingStates = DockingStateEnum.kDockBottom | DockingStateEnum.kDockTop;
docableWin.SetMinimumSize(200, 150);
if (!docableWin.IsCustomized)
    docableWin.DockingState = DockingStateEnum.kDockRight;
    docableWin.Visible = true;
form.Show();
any on has some idea why it does not work or what i can try to make it work.
Jelte de Jong
Blog: hjalte.nl - github.com
Replies (9)
Message 2 of 10
HideoYamada
The Dockable Window which is created with follow code is resizable in my enviroment.
public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime)
    // This method is called by Inventor when it loads the addin.
    // The AddInSiteObject provides access to the Inventor Application object.
    // The FirstTime flag indicates if the addin is loaded for the first time.
    // Initialize AddIn members.
    m_inventorApplication = addInSiteObject.Application;
    var inventor = m_inventorApplication;
    // TODO: Add ApplicationAddInServer.Activate implementation.
    // e.g. event initialization, command creation etc.
    //Form1 form = new Form1(inventor);
    Form form = new Form();
    form.BackColor = System.Drawing.SystemColors.Highlight;
    form.FormBorderStyle = FormBorderStyle.None;
    form.Show();
If you can resize the dockable window with this code, the issue will be depending on Form1.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 10
JelteDeJong
Thank you for your reply but it did not get it to work. I used your code and created a new form (and did not change any thing on the form.) but it still does not resize. Do i need to change some properties of the form?
Jelte de Jong
Message 4 of 10
HideoYamada
I attached the source code and binary image to this post.
Try with this files and let me know it works properly or not.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 5 of 10
HideoYamada
The binary was compiled for Inventor 2020.
I recompiled for Inventor 2018 and attached to this post.
Freeradical
 Hideo Yamada
Message 6 of 10
bradeneuropeArthur
Hi?
Have you tried the dockablewindowenents in inventor?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 10
bradeneuropeArthur
Hi @JelteDeJong  I Think I found a solution for this.
Works at least for my dockableWindows.
Use the Inventor Application Events to set the Height for the Form or the Control in you DockableWindow!
 Private Sub m_AppEvents_OnActivateView(ViewObject As Inventor.View, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_AppEvents.OnActivateView
            m_Form.Height = My_DockableWindow.Height
        End Sub
Hope this explaining is sufficient?
Otherwise I will give you my complete code.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
JelteDeJong
@bradeneuropeArthurI tryed your code and I tracked when the event is triggerd but it did not seem to be triggerd when the i tryed to resize the dockable window. So no luck with that event.
@HideoYamadaThank you for sending the example addin. Your example addin was also not resizing.
i discoverd that it is possible to resize my dockable window in the following way:
  • Undock the model browser
  • Put the model browser and my dockable window in the same frame.
  • Resize the model browser.
  • switch to my dockable window.
  • now its possible to resize......
that is far from how it is supposed to work. Im starting to wonder if the problem is my computer. (Also because the example of @HideoYamada does not work.) i will test this later on my job. If you have more ideas that they are still welcome. anyway i will keep you posted
Jelte de Jong
Message 9 of 10
bradeneuropeArthur
Hi @JelteDeJong
For me also that works.
I can take the DockableWindow (Floating) also this resizes correctly...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
HideoYamada
Have you already tried empty dockable window?
Or, more simply :
UserInterfaceManager uiMan = inventor.UserInterfaceManager; docableWin = uiMan.DockableWindows.Add("###############", "###############", "###############"); docableWin.Visible = true; }
Do you have other dockable window which you made and the client-id (first arg of Add Method) is same as test code ("###############") ?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
