Change the Derive Style of a derived assembly in VBA
shastu
Advisor Advisor
shastu
I have code to create a derived assembly based off of the active file.  All I need is a way to change the Derive Style but can't seem to figure it out.  I have included a screenshot of what I am trying to accomplish only I need to be able to do it through the API.
HideoYamada
Hello shastu,
Set DerivedAssemblyDefinition.DeriveStyle Property.
Function CreateDerivedAssy(FullFileName As String) As DerivedAssemblyComponent
    Dim oPartDoc As PartDocument: Set oPartDoc = ThisApplication.ActiveDocument
    Dim oPartDef As PartComponentDefinition: Set oPartDef = oPartDoc.ComponentDefinition
    Dim oDerivedAssys As DerivedAssemblyComponents: Set oDerivedAssys = oPartDef.ReferenceComponents.DerivedAssemblyComponents
    Dim oDerivedDef As DerivedAssemblyDefinition: Set oDerivedDef = oDerivedAssys.CreateDefinition(FullFileName)
    ' This changes Derive Style!
    oDerivedDef.DeriveStyle = kDeriveAsSingleBodyWithSeams
    Set CreateDerivedAssy = oDerivedAssys.Add(oDerivedDef)
End Function
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
shastu
Thank you so much!!!  I didn't realize that I had to do it within a function.  I was trying to get it accomplished within my sub.
