Dimension Outside
Dimension Outside
bradeneuropeArthur
Mentor Mentor
Dimension Outside
bradeneuropeArthur
How to move the dimension outside via coding?
And how to see if a dimension is moved outside via coding?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JelteDeJong
You can give this a go:
Sub Main()
    Dim doc As DrawingDocument = ThisDoc.Document
    Dim sheet As Sheet = doc.ActiveSheet
    Dim dimension As LinearGeneralDimension = 'sheet.DrawingDimensions.GeneralDimensions.Item(1)
        ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick a Linear dimansion")
Dim inside As Boolean = dimensionTextIsInside(dimension) MsgBox("Dimension text is inside = " & inside) placeTextOutside(dimension) End Sub Public Function dimensionTextIsInside(dimension As LinearGeneralDimension) As Boolean Dim textAboveLine As Double = 0.4 'Cm Dim lineSegment As LineSegment2d = dimension.DimensionLine Dim p1 As Point2d = lineSegment.StartPoint Dim p2 As Point2d = lineSegment.EndPoint Dim pText As Point2d = dimension.Text.Origin ' pythagoras at work but without taking the root as it is not needed here Dim lengthLineSegment As Double = (p2.X - p1.X) ^ 2 + (p2.Y - p1.Y) ^ 2 lengthLineSegment = lengthLineSegment + textAboveLine ^ 2 Dim p1ToText As Double = (pText.X - p1.X) ^ 2 + (pText.Y - p1.Y) ^ 2 Dim p2ToText As Double = (pText.X - p2.X) ^ 2 + (pText.Y - p2.Y) ^ 2 Return (p1ToText + p2ToText < lengthLineSegment) End Function Public Sub placeTextOutside(dimension As LinearGeneralDimension) Dim dinstanceOutside As Double = 1 ' Cm Dim textAboveLine As Double = 0.4 'Cm Dim lineSegment As LineSegment2d = dimension.DimensionLine Dim p1 As Point2d = lineSegment.StartPoint Dim p2 As Point2d = lineSegment.EndPoint Dim angle = Math.Atan((p2.X - p1.X) / (p2.Y - p1.Y)) Dim diffX As Double = dinstanceOutside * Math.Sin(angle) + textAboveLine * Math.Cos(angle) Dim diffY As Double = dinstanceOutside * Math.Cos(angle) + textAboveLine * Math.Sin(angle) Dim oTg = ThisApplication.TransientGeometry dimension.Text.Origin = oTg.CreatePoint2d(p2.X + diffX, p2.Y + diffY) If (dimensionTextIsInside(dimension)) Then dimension.Text.Origin = oTg.CreatePoint2d(p2.X - diffX, p2.Y - diffY) End If End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
bradeneuropeArthur
Thanks @JelteDeJong
That is really a nice and clever piece of code.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Hi @JelteDeJong
How would you prevent the dimension not is line with the dimension line?
Seems to have to do with where point 1 and point 2 is.
If it is a positive or a negative angle.
for example is it 90 degrees or -90 degrees or 270 degrees.
I will also have a look but maybe you have a quicker solution for it.
Thanks in advance.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
JelteDeJong
I did have a look but i cant help you....
Jelte de Jong
bradeneuropeArthur
Thanks anyway
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
