Microsoft Learn to Inventor Learn
andrew_canfield
andrew_canfield
IF
THE CODE I WRITE = WHAT I'D LIKE
THEN
BE AMAZED
ELSE
CTRL + ALT + DEL = REPEAT
I've discovered many resources but the Mircosoft site is huge - which bits of Microsoft learn are most relevant to writing programs for Inventor?
The folks on this site are amazing, I'd like to do more myself & not pester so much.
https://docs.microsoft.com/en-us/learn/tv/
Nobody said it was going to be easy.
Regards
Andrew
A.Acheson
What language have you had the most use with or are the most comfortable with?
You ask a good question so hopefully this post will build up some good conversation. I haven’t really navigated the Microsoft information directly more so go there when needed.
Regards
Alan
andrew_canfield
Hello Alan
I can ilogic a little, VBA not quite, Visual Studio Basic a very little - then a chasm opens up accessing Inventor's API.
LinkedIn learning offers plenty of api add-in for excel & there's many tutorials using excel's macro tool - which I haven't used.
Regards
Andrew
A.Acheson
VBA/iLogic editor
For me I started just with the ilogic straight in the rule editor, then VBA in excel, then figured out how to change VBA rules to work in ilogic editor. All mostly working backwards from finished rules and finding out what piece of code does what.
Here is a good explanation of what some of the languages do.
https://forums.autodesk.com/t5/inventor-customization/ilogic-vs-vba-similarities-differences-and-adv...
I suppose because VB.NET is the most compatible with ilogic so it may be easier. But VBA is probably more commonly used in terms of content creation and debugging.
For learning solely inventor the API help has the best information and has samples that pop up on this forum where user start to modify based on specific needs. For me I spent many months hearing about The API help but actually couldn’t figure out where it was referenced, it is here.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
Navigating it is a whole other ball game.
It uses VBA as its basis for sample codes. But if you are able to define the keywords you need you will be able to connect the snippets. I would generally just search for words that appear in the user interface as you are most likely looking to automate a manual process.
Regards
Alan
