Error on Sweep Feature VBA, Inventor
there is code, Is anybody know how to fix it?
Where is the place I can learn the VBA in Inventor?
Thank you!
bradeneuropeArthur
can you upload it as text?
In the programming help file in Inventor.
Thank you!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
_dscholtes_
You need to create a sweep definition first, in order to add a sweep.
This is an excerpt from an article on Manufacturing DevBlog:
Dim oSweepDef As SweepDefinition
Set oSweepDef = oCompDef.Features.SweepFeatures.CreateSweepDefinition( _
        kPathSweepType, oProfile, oPathNew, kSurfaceOperation)
Dim oSweepOne As SweepFeature
Set oSweepOne = oCompDef.Features.SweepFeatures.Add(oSweepDef)
I recently wrote code creating a sweep and used Google to find me some posts / blog articles.
Never bookmarked them, because I got it working.
