You can give this a go:
Sub Main()
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim dimension As LinearGeneralDimension = 'sheet.DrawingDimensions.GeneralDimensions.Item(1)
ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Pick a Linear dimansion")
Dim inside As Boolean = dimensionTextIsInside(dimension)
MsgBox("Dimension text is inside = " & inside)
placeTextOutside(dimension)
End Sub
Public Function dimensionTextIsInside(dimension As LinearGeneralDimension) As Boolean
Dim textAboveLine As Double = 0.4 'Cm
Dim lineSegment As LineSegment2d = dimension.DimensionLine
Dim p1 As Point2d = lineSegment.StartPoint
Dim p2 As Point2d = lineSegment.EndPoint
Dim pText As Point2d = dimension.Text.Origin
' pythagoras at work but without taking the root as it is not needed here
Dim lengthLineSegment As Double = (p2.X - p1.X) ^ 2 + (p2.Y - p1.Y) ^ 2
lengthLineSegment = lengthLineSegment + textAboveLine ^ 2
Dim p1ToText As Double = (pText.X - p1.X) ^ 2 + (pText.Y - p1.Y) ^ 2
Dim p2ToText As Double = (pText.X - p2.X) ^ 2 + (pText.Y - p2.Y) ^ 2
Return (p1ToText + p2ToText < lengthLineSegment)
End Function
Public Sub placeTextOutside(dimension As LinearGeneralDimension)
Dim dinstanceOutside As Double = 1 ' Cm
Dim angle = Math.Atan((p2.X - p1.X) / (p2.Y - p1.Y))
Dim diffX As Double = dinstanceOutside * Math.Sin(angle) + textAboveLine * Math.Cos(angle)
Dim diffY As Double = dinstanceOutside * Math.Cos(angle) + textAboveLine * Math.Sin(angle)
Dim oTg = ThisApplication.TransientGeometry
dimension.Text.Origin = oTg.CreatePoint2d(p2.X + diffX, p2.Y + diffY)
If (dimensionTextIsInside(dimension)) Then
dimension.Text.Origin = oTg.CreatePoint2d(p2.X - diffX, p2.Y - diffY)
End If
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
