Detect a phantom inside a phantom
Remy-intl
Remy-intl
Hello.
Our ERP bug if we put a phantom assembly in a phantom assembly...
Is it possible to control this from ilogic?
How to run a rule in the top assembly and check in all levels of all assemblies below.
Thanks a lot.
bradeneuropeArthur
try this:
Public Sub main
	Dim a As Inventor.Application = ThisApplication
	Dim b As Inventor.AssemblyDocument = a.ActiveDocument
	Dim c As Inventor.AssemblyComponentDefinition
	End Sub
	Public Sub Loopi (a As Inventor.AssemblyDocument)
		Dim b As Inventor.ComponentDefinition = a.ComponentDefinition
		Dim occs As Inventor.ComboBoxDefinition = b.Occurrences
		Dim occ As Inventor.ComponentOccurrence
		Dim occdoc As Inventor.AssemblyDocument'.Document
		For Each occ As Inventor.ComponentOccurrence In occs
			occdoc = occ.Definition.Document
			If occdoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
				MsgBox(occ.BOMStructure)
				Loopi(occdoc)
			Next
		End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Remy-intl
Thanks for your time.
I have an error on ligne 15. Do you have any idea?
Thanks.
bradeneuropeArthur
Public Sub main
	End Sub
		Dim occs As Inventor.ComponentDefinition = b.Occurrences
				Loopi(occdoc)
			Next
		End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
dutt.thakar
@Remy-intl
I would like to update the code provided by @bradeneuropeArthur . See below, this will show you the assembly name and the corresponding BOM structure in the message box.
Public Sub Main
	Call Loopi(b)
	End Sub
		Dim occs As Inventor.ComponentOccurrences = b.Occurrences
		'.Document
		For Each occ In occs
			If occ.DefinitionDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
				MsgBox(System.IO.Path.GetFileName(occdoc.FullFileName) & "----" & occ.BOMStructure.ToString)
				Loopi(occdoc)
			Next
		End Sub
 Hope this will help.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
bradeneuropeArthur
@dutt.thakar
Good addition/modification!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
