PresentationObject doesn't support Rebuild method?
WK-VA
WK-VA
Hi all,
Why does this
' I know it's an IPN file!
Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
' Either this...
oModelDoc.Rebuild
' ...or this
oModelDoc.Rebuild2 (True)
 fail with Runtime error 445 "Object doesn't support this action"?
The documentation clearly states that Rebuild as well as Rebuild2 are methods of Document and PresentationDocument class...?
Thanks in advance!
bradeneuropeArthur
Because an Ipn cannot be rebuild!
Only the referenced Assembly can be rebuild.
Try this:
Dim d As Inventor.DrawingDocument = ThisDrawing.Document
Dim v As Inventor.DrawingView = d.Views.Item(1)
Dim omodeldoc As Inventor.AssemblyDocument
omodeldoc = v.ReferencedDocumentDescriptor.ReferencedDocument
Dim adoc As Inventor.Document = omodeldoc.ReferencedDocuments.Item(1)
adoc.Rebuild
adoc.Rebuild
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WK-VA
Well, by trial and error, I noticed, that
Rebuild
Rebuild2
Update2
are not supported by PresentationDocument, while
Update
seems to be supported.
On the other hand, then your documentation seems to be completely off... (See attached screenshots, I'm obviously too dumb to include them into the posting right now...)
I thought that at least the VBA object browser reference sheets would be generated automatically, based on the respective classes definitions?
bradeneuropeArthur
That seems to be not correctly documented than!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
WK-VA
That's what I think as well...
Just for clarification: Are you member of the official Autodesk team?
If yes, then I would consider your statement as an official confirmation of the facts and thus mark the topic as solved.
bradeneuropeArthur
Hi @WK-VA
I am an Autodesk Expert Elite Member and not part of the Autodesk Team.
So the statement is only a assumption!
@johnsonshiue could you ask the development team for a confirmation!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
