@Remy-intl
I would like to update the code provided by @bradeneuropeArthur . See below, this will show you the assembly name and the corresponding BOM structure in the message box.
Public Sub Main
Dim a As Inventor.Application = ThisApplication
Dim b As Inventor.AssemblyDocument = a.ActiveDocument
Dim c As Inventor.AssemblyComponentDefinition
Call Loopi(b)
End Sub
Public Sub Loopi (a As Inventor.AssemblyDocument)
Dim b As Inventor.ComponentDefinition = a.ComponentDefinition
Dim occs As Inventor.ComponentOccurrences = b.Occurrences
Dim occ As Inventor.ComponentOccurrence
'.Document
For Each occ In occs
If occ.DefinitionDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
Dim occdoc As Inventor.AssemblyDocument
occdoc = occ.Definition.Document
MsgBox(System.IO.Path.GetFileName(occdoc.FullFileName) & "----" & occ.BOMStructure.ToString)
Loopi(occdoc)
End If
Next
End Sub
Hope this will help.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
