Derived Component names
DonStauffer99
DonStauffer99
Is there a way to change the names of the parts in the browser of a derived part? Randomly, some of them have gotten .ipt on the end of them, like filenames, but not all of them. This messes me up when I try to look up a derived component in code. For example, this code:
SyntaxEditor Code Snippet
Dim dpcs As DerivedPartComponents
dpcs = ThisApplication.ActiveDocument.ComponentDefinition.ReferenceComponents.DerivedPartComponents
Dim s As String
Dim i As Integer = 0
For Each dpc As DerivedPartComponent In dpcs
	i = i + 1
	If i > 1 Then s = s & Chr(10)
	s = s & dpc.Name
Next
MsgBox(s)
 Produces the results in the attached screen shot: some of the parts have .ipt extensions, and some don't. Nothing I've tried has enabled me to change the names. The Name property of DerivedPartComponents is read-only, too.
Any suggestions?
bradeneuropeArthur
I have tried that too for a while and I think this is not possible. Maybe this is something for idea station.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
DonStauffer99
I did some experimenting. I think part of the problem is that I've changed part names a few times. For example, I have a part named Front Right Joint. That's what the document DisplayName shows. Using this script on it gives different results depending on whether parts are loaded or not, and whether the link is suppressed or not, in 2 ways: 1. Sometimes the RefDoc.DisplayName is Nothing; 2. Sometimes the Descriptor.DisplayName comes back as "Front Right Side Joint", which is a name the part used to have.
So, to summarize, dpc.Name sometimes has the file extension on it, Descriptor.DisplayName sometimes has an old part name in it, and RefDoc is sometimes Nothing. So none of these will reliably identify the DerivedPartComponent I want by DisplayName. I could use string functions to strip off the .ipt, but I want a robust solution and that seems fragile.
Dim Descriptor As DocumentDescriptor
Dim RefDoc As Document
Dim s As String
	i = i + 1
	If i > 1 Then s = s & Chr(10) & CHR(10)
	If dpc Is Nothing Then
		s = s & Chr(10) & "dpc Is Nothing"
		Continue For
	End If
	s = s & "Dpc.Name=" & dpc.Name
    Descriptor = dpc.ReferencedDocumentDescriptor
	If Descriptor Is Nothing Then
		Continue For
	End If
	s = s & Chr(10) & " Descriptor.DisplayName=" _
			& Descriptor.DisplayName
	RefDoc = Descriptor.ReferencedDocument
	If RefDoc Is Nothing Then
		s = s & Chr(10) & "RefDoc Is Nothing"
		Continue For
	End If
	s = s & Chr(10) & " RefDoc.DisplayName=" _
			& RefDoc.DisplayName
Next
MsgBox(s)
DonStauffer99
I was able to work around this by comparing Document.FullFileName to ReferencedDocumentDescriptor.FullDocumentName.
I wasn't sure if I should have used Document.FullDocumentName instead, because the property names would be the same. But going by the documentation, the descriptions of these two were the same and the descriptions of the ones with the same property names were oddly not the same. But all 3 seemed to produce the same string for me.
I'm not entirely satisfied this workaround won't break under some circumstances, though.
DonStauffer99
I was right. It broke.
ReferencedDocumentDescriptor.FullDocumentName gave an old filespec with a different directory on one of the parts.
It seems like ReferencedDocumentDescriptor properties don't ever update themselves; then when a link is suppressed, they dredge up ancient history instead of the last known values. This is really unhelpful.
If I have a suppressed derivation to a part, I need to be able to reliably find the correct DerivedPartComponent for it. Otherwise how can I un-suppress it in code?
DonStauffer99
Please don't say "re-derive the part". With the stuff that's built on it, that would be hellish. I'd have to recreate the whole project from scratch - something I've already had to do a dozen times or more. That's one of the worst things about Inventor.
DonStauffer99
Current workaround now is to compare these two:
System.IO.Path.GetFileNameWithoutExtension(Document.FullFileName)
System.IO.Path.GetFileNameWithoutExtension(DerivedPartComponent.ReferencedDocumentDescriptor.FullDocumentName)
