Identifying Base Component
NachoShaw
Advisor Advisor
NachoShaw
Hi
Is there a coded method of identifying a Base Component as in, the original Base Model that a part has been derived from? In the UI, i can:
  • Open a part
  • Right click on Derived Part feature in the tree
  • select 'Open Base Component'
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bradeneuropeArthur
with this you can:
Public Sub SuppressLinkderivedpart()
Dim oInvApp As Inventor.Application
Set oInvApp = ThisApplication
        ' Set a reference to the Active document as a Part
        Dim oInvPartDocument As PartDocument
        Set oInvPartDocument = oInvApp.ActiveDocument
        ' Set a reference to the part component definition
        Dim oInvPartCompDef As PartComponentDefinition
        Set oInvPartCompDef = oInvPartDocument.ComponentDefinition
        ' Set a reference to the derived part component
        Dim oDerivedPart As DerivedPartComponent
        Set oDerivedPart = oInvPartCompDef.ReferenceComponents.DerivedPartComponents.Item(1)
MsgBox oDerivedPart.ReferencedDocumentDescriptor.FullDocumentName
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
NachoShaw
appreciate it
thanks
Nacho
bradeneuropeArthur
I also appreciate to help on the forum.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
