Delete all linear dimensions from the drawing
manu.marjanen
manu.marjanen
How do i get removed all linear dimensions from the drawing?
I found a few codes online but did not work for me.
bradeneuropeArthur
Try this:
Dim a As Inventor.DrawingDocument = ThisDrawing.Document
Dim b As Inventor.Sheet = a.ActiveSheet
For Each c As Inventor.DrawingDimension In b.DrawingDimensions
	If c.Type = Inventor.ObjectTypeEnum.kLinearGeneralDimensionObject Then
		c.Delete
	End If
	Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
manu.marjanen
This works, thanks
