How to add text in front of the dimension
manu.marjanen
manu.marjanen
How to edit this code, so that i can get text in front of the dimension?
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim FRONT = Sheet_1.DrawingViews.ItemByName("FRONT")
Dim Work_Point1 = FRONT.GetIntent("Work Point1")
Dim Work_Point2 = FRONT.GetIntent("Work Point2")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
	Dim linDim1 = genDims.AddLinear("Dimension 1", FRONT.SheetPoint(0.5, 1.2), Work_Point1, Work_Point2)
yan.gauthier
either Text or FormattedText property. One corresponds to when you double the dimension. the other when you right click the dimension and select edit text
linDim1.Text.FormattedText
JelteDeJong
try this:
linDim1.Text.FormattedText = "Before dimension <DimensionValue/> after dimension"
Jelte de Jong
Blog: hjalte.nl - github.com
manu.marjanen
Give an error message. Error on line 7:
JelteDeJong
linDim1.NativeEntity.Text.FormattedText = "Before dimension <DimensionValue/> after dimension"
Jelte de Jong
manu.marjanen
This works, thanks
myronHBBUW
@JelteDeJong,
Do you also know how to get the arrowheads outside?
