Custom properties to description
kresh.bell
kresh.bell
is it possible to create an iLogic that will assign a combination of custom properties to each part in the assembly?
For example, a part in an assembly has these custom properties
Value: 82
Value: 100
Item.FillWorkpiece.Material.Thickness
Value: 18
I would like to start iLogic in the assembly environment and for the description of the part to be:
100 x 82 x 18
bradeneuropeArthur
<span;>Description
<span;>Value is <<span;>Item.FillWorkpiece.Width> x < Item.FillWorkpiece.Length>×
<span;><Item.FillWorkpiece.Material.Thickness>
<span;>No code needed</span;></span;></span;></span;></span;>
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Curtis_Waguespack
@kresh.bell, This will add the formula to the Description iproperty
iProperties.Value("Project", "Description") = "= <Width> x <Length> x <Thickness>"
bradeneuropeArthur
And no coding needed at all!
@Curtis_Waguespack
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Curtis_Waguespack
I think that depends on the situation. If we are working with a template, then adding the formula to the description iProperty in the template provides a no-code solution.
If we're wanting to work with many existing files, then adding the formula to the description iProperty with a line code like this would be more efficient.
