Create ribbon with vba
nucliabrasil
nucliabrasil
Hi !
Is it possible ?
bradeneuropeArthur
Please explain a little more what you need, because a/the ribbon is always there.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JhoelForshav
Hi @nucliabrasil
Do you want to create a new ribbon tab?
Here is an example i made in iLogic. Should be easy to rewrite as VBA code.
Class ThisRule
Sub Main
            ' Get the assembly ribbon.
            Dim AssemblyRibbon As Ribbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Assembly")
            ' Create a new tab.
            Dim oTab As RibbonTab = AssemblyRibbon.RibbonTabs.Add("New Tab", "id_newTab", Guid.NewGuid().ToString())
            ' Create a new panel.
            Dim oPanel As RibbonPanel = oTab.RibbonPanels.Add("New Panel", "id_newPanel", Guid.NewGuid().ToString())
 Dim controlDefs As Inventor.ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions
            Dim m_sampleButton As ButtonDefinition = controlDefs.AddButtonDefinition("Button", "oButton", CommandTypesEnum.kShapeEditCmdType)
            ' Add a button.
            oPanel.CommandControls.AddButton(m_sampleButton, True)
	End Sub
 End Class
 This should really be done in an AddIn but you can do it this way
JhoelForshav
The code i posted creates a tab in the assembly environment. So if you run it from within a part you won't see the tab appear. I'm sure you can tell by the code but I might as well mention it 🙂
