iLogic - How to access Drawing / Sheet properties
j.pavlicek
j.pavlicek
is somehow possible to read this two Properties with iLogic?
Thank you!
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Sergio.D.Suárez
Hi, I think this code could serve you.
Maybe adapting it to your need
Dim oDoc As DrawingDocument= ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
'Calculate number of sheets
Dim oSheetNumbers As String = oDoc.Sheets.Count
Dim i As Integer, SheetNumber As Integer
For i = 1 To oSheetNumbers
	If oDoc.Sheets(i).Name = oSheet.Name Then
		SheetNumber = i
		Exit For
Next
MessageBox.Show( "Number of sheets: " & oDoc.Sheets.Count)
MessageBox.Show( "SheetNumber: " &SheetNumber)
If you want to add this property to a note, you should access in a similar way to this.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oView As DrawingView = oDoc.ActiveSheet.DrawingViews(1)
oView.Label.FormattedText = "<StyleOverride><DerivedProperty DerivedID='29704'>Sheet Number</DerivedProperty></StyleOverride><Br/><StyleOverride><DerivedProperty DerivedID='29703'>Number of sheets</DerivedProperty></StyleOverride>"
 In this example, the label of the view of a drawing file will be changed with the two values you are looking for.
I hope this helps with your problem.
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
j.pavlicek
Thanks for reply. I hoped for easy acces for this numbers from some object.
Your code is ok, until there are no sheets excluded from count. So I wrote my own functions.
Maybe helps someone in future.
'From given sheet object returns its number. When excluded from counting, returns 0
Public Function iSheetNumber(ByVal oSheet As Sheet) As Integer
	Dim oDoc As Document
	Dim oSheetB As Sheet
	Dim sName As String
	Dim i As Integer
	Dim j As Integer
	'name of given sheet
	sName = oSheet.Name
	oDoc = oSheet.parent
	j = 0
	'For each sheet in document
	For i = 1 To oDoc.sheets.count
		oSheetB = oDoc.sheets(i)
		'If is NOT excluded from counting
		If oSheetB.excludefromcount = False Then
			'Increase counter by 1
			j = j + 1
		'If it is given sheet
		If oSheetB.name = sName Then
			'Check if is NOT excluded from counting
				'Not excluded = quit with current counter (j)
				Exit For
			Else
				'Excluded from counting = set counter to 0
				j = 0
				Exit For
	Next i
	'Retruns counter
	Return j
End Function
'Return total count of sheets in doc with given sheet
Public Function iSheetsCount(ByVal oSheet As Sheet) As Integer
	Dim i As Integer
	Dim j As Integer
	sName = oSheet.Name
	'parent document of given sheet
	j = 0
			j = j + 1
	Next i
	'Retruns counter
	Return j
End Function
