Convert several standard parts to sheet metal parts
MariaManuela
Advisor Advisor
MariaManuela
Hi All,
Its any api thats convert several imported standard parts to sheet metal parts?
I have an imported assembly (from NX) with more than 100 parts and i need convert all of then to sheet metal.
Any idea how can i speed up the process?
Thank you
Manuela
Inventor 2022
bradeneuropeArthur
Conversion is easily possible.
The uniform thickness will be the major issue here!
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
You can put this is a loop:
dim a as partdocument = thisdoc.document
Dim oRegAssy As String = "{E60F81E1-49B3-11D0-93C3-7E0706000000}"
Dim oWeldment As String = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}"
Dim oRegPart As String = "{4D29B490-49B2-11D0-93C3-7E0706000000}"
Dim oSheetMetal As String = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
if a.SubType = oRegPart
	MsgBox ("Covert to Sheet Metal Part")
	a.SubType = oSheetMetal
end if
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
