how would I do this in VBA ?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 14
I want to find a row in  an excel sheet , and  read other vaule in the same row . I know how to do it in ilogic , it does know seens to be so easy to rewrite the code to vba.  can you help me ?
dim ExcelPath
dim ExcelSheet
ExcelPath="C:\showprice\Showprice.xlsm"
ExcelSheet ="Price"
GoExcel.Open(ExcelPath, ExcelSheet)
GoExcel.TitleRow = 1
GoExcel.FindRowStart = 2
'NO_ collum = column A
'Raw" collum = column B
'Part Description collum = column C
Dim rowNo = GoExcel.FindRow(ExcelPath, ExcelSheet, "No_", "=", CurrentSM_Style)
If rowNo > 0 Then
RawMatrNo=GoExcel.CurrentRowValue("Raw") '
PartDescription=GoExcel.CurrentRowValue("Part Description")
GoExcel.Close
Accepted solutions (3)
Replies (13)
Message 2 of 14
Stakin
excelapp= CreateObject("Excel.Application")
excelapp.Visible = False
excelapp.DisplayAlerts = False
excelapp.Workbooks.Open(ExcelPath)
mainsheet=excelapp.ActiveWorkbook.WorkSheets(ExcelSheet)
mainData = mainsheet.Range("A3").CurrentRegion.Value
excelapp.Quit
Message 3 of 14
how do I get the infomation out ? does your code not just open the excel doc ?
Message 4 of 14
Ralf_Krieg
Hello
I assume position of columns NO_, Raw and PartDescription are unknown, so we have to find it first. Try this:
Private Sub FindValue(ByVal CurrentSM_Style As String)
    Dim oExcelApp As New Excel.Application
    Dim ExcelPath As String
    ExcelPath = "C:\showprice\Showprice.xlsm"
    Dim ExcelSheet As String
    ExcelSheet = "Price"
    Dim oWB As Excel.Workbook
    Set oWB = oExcelApp.Workbooks.Open(ExcelPath)
    Dim oWS As Excel.WorkSheet
    For Each oWS In oWB.Sheets
        If oWS.Name = ExcelSheet Then Exit For
    Next
    Dim RawMatrNo As String
    RawMatrNo = getcellvalue(oWS, "Raw", CurrentSM_Style)
    Dim PartDescription As String
    PartDescription = getcellvalue(oWS, "PartDescription", CurrentSM_Style)
    'for debugging
    MsgBox ("CurrentSM_Style= " & CurrentSM_Style & vbCrLf _
            & "RawMatrNo= " & RawMatrNo & vbCrLf _
            & "PartDescription= " & PartDescription)
    oWB.Close (False)
    oExcelApp.Quit
End Sub
Function getcellvalue(oWS As WorkSheet, ct As String, rt As String) As String
    Dim colNo As Long
    colNo = Application.WorksheetFunction.Match("NO_", oWS.Rows(1), 0)
    Dim rowNo As Long
    rowNo = Application.WorksheetFunction.Match(rt, oWS.Columns(colNo), 0)
    colNo = Application.WorksheetFunction.Match(ct, oWS.Rows(1), 0)
    getcellvalue = oWS.Cells(rowNo, colNo)
End Function
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 5 of 14
I keep getting all sort of error...I did remove some of them ... but it seens I stock with this one .
And anyone see why ?
Dim oExcelApp
ExcelPath = "C:\Working Folder\CAD\Kallesoe\Kallesoe iLogic\ShowPrices.xlsm"
Dim oWB
Dim oWS
Next
RawMatrNo = getcellvalue(oWS, "Unit Cost", "3095006030")
' Dim PartDescription As String
' PartDescription = getcellvalue(oWS, "PartDescription", CurrentSM_Style)
'for debugging
& "RawMatrNo= " & RawMatrNo)
oWB.Close (False)
oExcelApp.Quit
'END CODE
If Msg = "Flat Bars" And Msg2 = "Steel" And msg3 = "Flat Bar, Hol Rol.-StS235" And msg4 = "30 x 6" Then
ShowPrice.KostPris.Caption = "100 kr"
End Sub
Function getcellvalue(oWS, ct As String, rt As String) As String
Dim colNo As Long
Dim rowNo As Long
End Function
Message 6 of 14
bshbsh
oExcelApp is not instanced. you need to create the object before you can use it.
Message 7 of 14
Ralf_Krieg
Hello
Don't know why you strip my example the way it doesn't work anymore. You need to create the instance as bshbsh said and i wrote in my example.
If this throws an error, check in VBA references if you have enabled the reference to the "Microsoft Excel XX.0 Object Library". Otherwise VBA don't "know" what an Excel.Application is.
R. Krieg
RKW Solutions
Message 8 of 14
I remove it because it cause an error on my computer like it was missing somthing. maybe needed to imports some extra code libraries(think it is call).
Message 9 of 14
Ralf_Krieg
Hello
Have you tried to add the reference to the Excel Library as I wrote in my last post? I think that's what is missing. Without this you get error messages about undefined user defined types and so on. To add this reference open the VBA editor window. Under menu "Tools" goto "References". In the window scroll down to "Microsoft Excel XX.0 Object Library" (XX.0 is the internal version number, Excel 2019 has 16.0) and activate it. Close the dialog with OK and try again.
R. Krieg
RKW Solutions
Message 10 of 14
WCrihfield
You need to turn on the reference to your Excel application's API Object library.
Within the VBA Editor:
Click Tools tab > References...  (this will open a References dialog)
Then scroll down and check the check box beside the "Microsoft Excel 16.0 Object Library", then click the 'OK' button.
(The 16.0 part may be different on your maching...it relates to the version of Excel you have installed.)
After this is turned on, all those Excel related objects should be recognized within your VBA macros.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 11 of 14
thanks. I end of getting it kind of working. But still have a lot of fine turning to do
you dont happen to how have I can you it to open just ones(excel)? right not it open up a new ones each time I change the last selection.
Message 12 of 14
Ralf_Krieg
Hello
I modified my code from above to get a running instance or, if there's none, create a new one.
Option Explicit
    Dim oExcelApp As Excel.Application
    Set oExcelApp = GetExcelApplication
    ' create a dummy workbook and let it open, otherwise Excel will shutdown an macro end
    Dim oWB As Workbook
    If oExcelApp.Workbooks.Count = 0 Then
        Set oWB = oExcelApp.Workbooks.Add()
    'make Excel visible, otherwise you have to shutdown it by taskmanager :-/
    oExcelApp.Visible = True
    Next
    'for debugging
    oWB.Close (False)
    oExcelApp.Quit
End Sub
    Dim colNo As Long
    Dim rowNo As Long
End Function
Public Function GetExcelApplication() As Object
    On Error GoTo openExcel
    Set GetExcelApplication = GetObject(, "Excel.Application")
    Exit Function
openExcel:
    If Err.Number = 429 Then
        Set GetExcelApplication = CreateObject("Excel.Application")
    Else
        Debug.Print "Unhandled exception: " & Err.Number & " " & Err.Description
End Function
R. Krieg
RKW Solutions
Message 13 of 14
bshbsh
instead of using the New keyword to create the excel instance (which will open a new Excell every time) you can use the createobject() and getobject() functions.
Dim oExcelApp as Object
On Error Resume Next
Set oExcelApp = GetObject(, "Excel.Application")
If Err.Number <> 0 then
    Set oExcelApp = CreateObject("Excel.Application")
    Err.Clear
end if
On Error Goto 0
Message 14 of 14
WCrihfield
Here's another example of a similar routine that both @Ralf_Krieg  & @bshbsh provided examples for that attempts to either Get or Create an instance of Excel, while attempting to avoid the potential errors.  I don't use VBA nearly as much as I do iLogic & vb.net, so I had to dig for this one.  Similarly too, you can either use it by itself, or use it as a separate Function (with a couple minor tweaks).
I believe that back then I may have gotten some of the inspiration for it from the standard Microsoft page for the VBA use of GetObject() method.  Anyways, since I had just posted something so related to this situation on that other post, I would at least drop a link to that other post here too, just in case it may help anyone else out.
Wesley Crihfield
