To get an event triggered in the main plugin code when we click run rule for iLogic rule(internal rule) .
Hello guys, I am new to inventor and have been doing some programming related to Addins, just recently I started reading about iLogic rules and I am faced with the task to get an event triggered in the main code(the code for Addin) when we click on Run Rule of an internal rule created for some assembly which is currently opened in the inventor.
The main constraint is we are not creating the iLogic rule, but we need to get an event triggered in our code when we click run rule.
WCrihfield
I'm not an add-in guru, but I'm familiar with creating custom event handlers, and I don't think there is a pre-defined event (or method for handling the event) for when someone manually runs an iLogic rule that is exposed to Inventor's API at this time.  I couldn't even find the name of a ControlDefinition that might be executed when you manually run an iLogic rule, so I don't think you could even monitor for when that specific command is executed.
I could be wrong, but likely the only folks that know are going to be the folks who work for Autodesk directly, or maybe someone in their developer's network.
Wesley Crihfield
(Not an Autodesk Employee)
Thank you for your reply, will wait for any surprises to come from the answers, but thank you for verifying some of my findings.
JelteDeJong
Probably it not much help but just in case...
Maybe the IiLogicAutomation.EnterDelayedRuleRunningMode is some help to you. It will not give you a nice trigger but if you are running a process it can help to stop iLogic rules from running until you want them to run. Or if you know that the rule is going to be triggerd then put iLogic in this "delayed rule running mode". Do your stuff and exit the "delayed rule running mode.
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you for the reply and the suggestion, will try playing around with what you suggested, it's much better than blindly searching for a solution.
