content center crashes after publishing in 2020
Message 1 of 56
Problem in inventor 2020. Content center crashing after modifying a group and publishing
Screen freezes and you have to close Inventor to carry on.
Can Autodesk apply a hot fix to fix this please?
Replies (55)
Message 41 of 56
Jan,
I think there is something wrong with inventor or my settings,
can you think of anything.
I have redone the I part from scratch and simplified it and it still says 'Unable to create componant'
I have followed your steps to publish the part as well.
Your help would be greatly appreciated
Message 42 of 56
bradeneuropeArthur
Could you please take a look at the question?
Because we are near to a solution for this I think!
Without your answer I am not able to solve...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 43 of 56
I want to move a sketch so it cuts in a different orientation.
unless i can do it another way?
Message 44 of 56
bradeneuropeArthur
You can do that with the Content Center Template too!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 45 of 56
how?
Please tell me
Message 46 of 56
jan_priban
Message 47 of 56
bradeneuropeArthur
could you show a screenshot what has to be moved.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 48 of 56
bradeneuropeArthur
Hi @jan_priban  exactly...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 49 of 56
Message 50 of 56
bradeneuropeArthur
Can you send the of the family members?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 51 of 56
I want t change the angle on one extruded cut so the box has a two angles like attached photo-45 +45 box.JPG
Message 52 of 56
bradeneuropeArthur
I am using Inventor 2018 here, this means I cannot open the file here at the moment.
Later this day I can open it with inventor 2020..
keep reading...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 53 of 56
Well Done.....
With a little bit of trial and error this worked
still cant understand why I could do it once and not after that ?
Message 54 of 56
bradeneuropeArthur
Short explanation:
inventor parts and i-parts have an internal fix name like a GUID.
This seems to be a problem with publishing more then once to the CC.
If you would do a save-as with the I part it should work.
With the provide method you bypass this. Hope that this solves the problem.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 55 of 56
bradeneuropeArthur
As promised the modified Content Center Template.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 56 of 56
doninelio
I have exactly the same problem and it's happening every time I try to modify something on the content center. It is frustrating and I don't see any solutions here.
