iProperties not updating in modified Enhanced SaveAs
I have a slight problem that I don’t understand as I am not a coder in the slightest.
I have modified Enhanced SaveAs ilogic to display a standard saveas dialog box by slicing together two lots of code.
The problem is I want to reset some iProperties in the drawing file before I save it to the new name. My code does not work when within the rest of the code but works in isolation when triggered manually. My code is an external rule.
Any help is greatly appreciated.
Here is the problem area that is not working;
'Reset Drawing creation date to today
Dim oTime As String = Now.ToShortDateString
iProperties.Value("Project", "Creation Date") = oTime
'Reset plot date stamp
iProperties.Value("Custom", "Plotdatestamp") = ""
iLogicVb.UpdateWhenDone = True
DrawingDoc.Update()
Full code (sorry if its messy 🙂 );
' Start of iLogic code -------------------------------------------------------------------------------------
' Note this iLogic rule takes a copy of the active part and associated drawing file
' ...then associates the drawing with the newly copied Part.
' This rule is a variation on a previous blog by Luke Davenport located here:
' https://www.cadlinecommunity.co.uk/hc/en-us/articles/203347701-Inventor-2016-iLogic-Copy-Assembly-Model-and-Drawing
' This rule allows any name to be input for the copied drawing and Part, the code in the blog linked above
' ...allows only a suffix to be entered.
' Set drawing extension you are using here by commenting out as required.
Dim DWGType As String = ".dwg"
'Dim DWGType As String = ".idw"
Dim oDoc As PartDocument = Nothing
Try
	oDoc = ThisApplication.ActiveEditDocument
Catch
	MsgBox("This rule must be run from the part document that you wish to copy! - Exiting...", 64, "Enhanced Save As")
	Return
End Try
' Get current filename without extension
Dim CurrentFilename As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullDocumentName)
' Get current path
Dim Path As String = System.IO.Path.GetDirectoryName(oDoc.FullDocumentName)
' Check that the drawing for this assembly can be found
If Not System.IO.File.Exists(System.IO.Path.ChangeExtension(oDoc.FullDocumentName, DWGType)) Then
	MsgBox("Unable to locate the drawing file below for this assembly:" & vbLf & vbLf & _
	CurrentFilename & DWGType & vbLf & vbLf & _
	"Please make sure it's in the same folder as this assembly, has the same name, and has the file extension '" & DWGType & "'", 64, "Enhanced Save As")
	Return
'define the active document
oDoc = ThisDoc.Document
'create a file dialog box
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
	oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
Else If oDoc.DocumentType = kDrawingDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = CurrentFilename
'work with an error created by the user backing out of the save
Try
	oFileDlg.CancelError = True
	oFileDlg.ShowSave()
Catch
	Return
End Try
'catch an empty string in the imput
If Err.Number <> 0 Then
ElseIf oFileDlg.FileName <> "" Then
	MyFile = oFileDlg.FileName
	'save the file
	oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
iLogicVb.RunExternalRule("Clear Properties")
iLogicVb.RunExternalRule("Extract_Properties")
' Prompt user for New Project Name
Dim NewProjectName As String = InputBox("You are creating a new copy of this design and its 2D drawing file" & vbLf & vbLf & _
"Please input a new project name.", "New Project Name", "Enter New Project Name Here")
If NewProjectName = "" Then ' Cancel was hit
	Return
iProperties.Value("Project", "Project") = NewProjectName
MyFile = ThisDoc.FileName(False)
Dim PathNew As String = ThisDoc.Path
' Open the current drawing (in same folder location)
Dim DrawingDoc As DrawingDocument = ThisApplication.Documents.Open(Path & "\" & CurrentFilename & DWGType)
' Replace reference to Part model
Dim oFD As FileDescriptor
oFD = DrawingDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
oFD.ReplaceReference(PathNew & "\" & MyFile & ".ipt")
DrawingDoc.Update()
'Update drawing properties to model properties
Dim oControlDef As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.​Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute2(True)
DrawingDoc.Update()
' Perform 'Save As' on the drawing - change this to reflect your drawing type .dwg or .idw
DrawingDoc.SaveAs(PathNew & "\" & MyFile & ".dwg", False)
'Close Drawing
'ThisApplication.ActiveDocument.Close(True)
' Make the Part model active again...
oDoc.Activate()
' End of iLogic code ---------------------------------------------------------------------------------------------
Mark.Lancaster
@Anonymous
This type of question should be posted in the Inventor customization forum for best results
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will ask the moderator to relocate your posting there.
Mark Lancaster
Thank you. Apologies.
Do I accept your solution here?
Mark.Lancaster
@Anonymous
No need for apology.   Smiley LOL
Also no need to select as solution.   I didn't provide an actual solution to your question..  Just posting or re-directing you to give you the best solution or outcome for your needs.
Mark Lancaster
I have now solved this. Please see my other post "My take on Enhanced Save As" for my solution and code that may be of use to you.
