content center crashes after publishing in 2020
Message 1 of 56
Problem in inventor 2020. Content center crashing after modifying a group and publishing
Screen freezes and you have to close Inventor to carry on.
Can Autodesk apply a hot fix to fix this please?
Replies (55)
Message 21 of 56
Hi Jan,
could you look at this ,
frame gen gave this error. I cant see what I am doing wrong anymore?
Message 22 of 56
jan_priban
If you republish square shape then it became new/different family. In this case Edit of existing frame could should such message. If you just place frame using FG, all should go fine. Try your square shape family simply by Place from Content Center. If you can place from CC then verify usage your family in Frame Generator
Jan Priban
Message 23 of 56
I cant place from cc either
Message 24 of 56
jan_priban
It means your iPart was not published successfully. Place from CC is first steps, it has to work without authorization. For Frame Generator, authoring is necessary. You need to make correct authoring, correct publish.
Beside that, I have no idea
Regards
Jan Priban
Message 25 of 56
could it be something wrong with my installation?
like I said it worked fine once. with this I Part,
all i did was delete an extrusion and try to republish
Message 26 of 56
bradeneuropeArthur
Sorry to ask things again!
I published an I part to my custom content center. So the I-part you still have available?
and it worked perfect. The Custom Content Center file worked fine I think?
I have taken the same base file and deleted an extrusion and then published the part again. What do you mean with the same base profile? Do you mean the I-part?
Did you re-publish it the the same Content Center family, or did you create a complete new one (new Content Center Family)? If you did not create a complete new one (new Content Center Family) that than i may have the solution!
When I go to insert the part it inventor is unable to create part. You mean the re-published Content Center Part?
Is there an issue with inventor in 2020 that would contribute to this.
Why would it work once and then not for a second time?
Please take a look at my questions and if you did re-publish the I-part again than i may have the solultion for it.
Looking forward to help you out.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 27 of 56
OK,
I created an I Part based on a content center part.
This part is a piece of box.
All I did was create an I part of this box with two 45 deg opposite cuts (miter) on each end.
I created various sizes of this box and published it to our custom content center. Everything worked fine.
In order to same me time i then opened the I part i just publish and deleted one of the extruded cuts to delete one of the 45 deg cut (miter) on the end.
and then followed the same process to publish it.
it said it published ok but when you try and insert from content center it comes up with a message 'Unable to Create Component'
I have tried everything other than recreate the original part
Message 28 of 56
bradeneuropeArthur
I created an I Part based on a content center part. How did Create The i-part based on the Content center Part, how did you do that?
I created various sizes of this box and published it to our custom content center. But you created new families for these Content Center files, or not?
Everything worked fine. With publishing it once. The second time goes wrong?
In order to same me time i then opened the I part i just publish and deleted (Don,t You mean delete and republish?) one of the extruded cuts to delete one of the 45 deg cut (miter) on the end. and then followed the same process to publish it.
it said it published ok but when you try and insert from content center it comes up with a message 'Unable to Create Component' I have tried everything other than recreate the original part
For my understanding are you always republishing the I-part or are you re-publishing the modified Content Center file?
And are you re-publising it because the file was wrong (you need a different shape!), because you needed to delete features?
Looking forward...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 29 of 56
correct,
I used a piece of box loaded from content center and put two miters on each end then created an I part from this with various sizes of box and then published it to my custom content center so I could pull in a piece of box the size and length i wanted wit two opposite miters on it.
It worked perfect.
But wont take the original I part I have already published and recreate a similar piece of box with only one miter.
Message 30 of 56
bradeneuropeArthur
Ok,
I am almost with you.
  1. You have created a I-part.ipt  (X001.ipt) from a Content Center File.
  2. You have published this to a Custom Content Center Family "shape X001"
  3. You have Modified the I-part.ipt  (X001.ipt) and published this to a Custom Content Center Family "shape X002".
  4. But you did not Modify the I-part.ipt  (X001.ipt) and re-published this to a Custom Content Center Family "shape X001" that already exist?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 31 of 56
No,
I modified the Ipart then republished so it only had one mite
Message 32 of 56
bradeneuropeArthur
Re-publishing means for me overwriting the existing one, did you do that?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 33 of 56
OK Published as a new content Center Part but reused a modified version of the original I part
Message 34 of 56
bradeneuropeArthur
Ok,
Than my concerns about your method is not he case.
But I almost always use a different approach for this copy a Content Center file.
What I do is copying the Content Center family and than manually replace the template with the modified one.
actually the same as you are doing with the I-part.
With the difference that I don't need to publish twice and that I am editing the Content Center Template and NOT the I-part. which can lead into issues, as you may see now.
Hope this will help you a lot, otherwise please ask.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 35 of 56
I have done that for others,
The problem is i need to modify a sketch to create this part
Message 36 of 56
bradeneuropeArthur
Why you cannot do that with the Content Center File (Template)?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 37 of 56
because I need to change the orientation of one sketch
Message 38 of 56
bradeneuropeArthur
With orientation you mean on a different wokplane?
Or rotated; moved...?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 39 of 56
NEEDED TO MOVE THE SKETCH
Message 40 of 56
bradeneuropeArthur
Why isn't this possible in your Content Center Template?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
