CommandManager.Pick (KDrawingWeldSymbol) Inventor 2024
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
How can I use the the commandmanager to select/pick a DrawingWeldingSymbol in Inventor 2024. The API now is available for DrawingWeldSymbols, but not for selection?
Any Ideas how to select these?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Michael.Navara
It looks like a bug. You can process only pre-selected symbols. Selection doesn't work in SelectEvents too.
According to this StackOverflow post I try to implement custom functionality similar to Pick method. But it doesn't work with drawing weld symbols. 😞
imports system.Threading.Tasks
Sub Main()
MainAsync()
End Sub
Private pickTcs As TaskCompletionSource(Of Boolean) = New TaskCompletionSource(Of Boolean)()
Private interactionEvts As InteractionEvents
Private selectEvts As SelectEvents
Async Sub MainAsync()
	interactionEvts = ThisApplication.CommandManager.CreateInteractionEvents()
	selectEvts = interactionEvts.SelectEvents
	AddHandler interactionEvts.OnTerminate, AddressOf interactionEvts_OnTerminate
	AddHandler selectEvts.OnSelect, AddressOf selectEvts_OnSelect
	interactionEvts.Start()
	Dim selectedSomething = Await pickTcs.Task
	Logger.Debug("Something selected: {0}", selectedSomething)
End Sub
Private Sub selectEvts_OnSelect(justSelectedEntities As ObjectsEnumerator, selectionDevice As SelectionDeviceEnum, modelPosition As Point, viewPosition As Point2d, view As Inventor.View)
	pickTcs.SetResult(True)
	StopInteraction()
End Sub
Private Sub interactionEvts_OnTerminate()
	pickTcs.SetResult(False)
	StopInteraction()
End Sub
Private Sub StopInteraction()
	interactionEvts.Stop()
	interactionEvts = Nothing
	selectEvts = Nothing
End Sub
bradeneuropeArthur
Hi Michael,
I was trying exact the same but no result. Seems as a bug indeed.
@johnsonshiue could you and your team have a look at it?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Michael.Navara
I found a solution! 😀
Imports System.Threading.Tasks
Sub Main()
MainAsync()
End Sub
Private userInputEvts As UserInputEvents
Private pickedObject As Object
	userInputEvts = ThisApplication.CommandManager.UserInputEvents
	AddHandler userInputEvts.OnSelect, AddressOf userInputEvts_OnSelect
	If (selectedSomething) Then
	Dim drwWeldSymbol As DrawingWeldingSymbol = TryCast(pickedObject, DrawingWeldingSymbol)
	If (Not drwWeldSymbol Is Nothing) Then
		Logger.Debug("DrawingWeldingSymbol picked")
End Sub
Private Sub userInputEvts_OnSelect(justSelectedEntities As ObjectsEnumerator, ByRef moreSelectedEntities As ObjectCollection, selectionDevice As SelectionDeviceEnum, modelPosition As Point, viewPosition As Point2d, view As Inventor.View)
	If (justSelectedEntities.Count > 0) Then
		pickedObject = justSelectedEntities(1)
		RemoveHandler userInputEvts.OnSelect, AddressOf userInputEvts_OnSelect
End Sub
bradeneuropeArthur
@Michael.Navara ,
Good job thanks.
I have learned something new also.
Where did you find this, or how did you come to this idea?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Michael.Navara
I know there are two events for selection UserInputEvents.OnSelect and SelectEvents.OnSelect both of them I used before. The first one is useful when you need to process any (relevant) entity selected by user, the second one is useful when you need to control what can be selected.
The rest is an implementation of  StackOverflow post mentioned above.
And also I like this challenges.
I hope it helps.
