check whether part is create by frame generator
Is it possible through the api to check whether a part has been created through frame generator? I'm trying to filter these parts out of a all referenced documents loop.
Hi Craig,
We use stock number to skip frame generator parts, but you could use any iproperty.
Our frame generator parts contain a stock number.
We also use the description iproperty so it skips the frame control sketch.
SyntaxEditor Code Snippet
'---start iLogic ----
'check for skip it flag
SN = iProperties.Value("Project", "Stock Number")
Desc = iProperties.Value("Project", "Description")
If IsNumeric(SN) = True Then
    Return
    ElseIf Desc = "Frame Control Sketch" Then
    Return
    Else
    """DO something here"""
End If
'---end iLogic ----
bradeneuropeArthur
It has a clasification. You could skip these on clasification = content center member.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
wolfgang_nickl
Hello Together,
you can check it with AttribueSets:
Sub wnTestFrame()
    Dim ASE As AttributeSetsEnumerator
    Dim Doc As Document
    Set Doc = ThisApplication.ActiveDocument
    Set ASE = Doc.AttributeManager.FindAttributeSets("com.autodesk.FG*", "*", "*")
    If ASE.Count > 0 Then MsgBox "Framegenerator Part/Assembly"
End Sub
Assemlies will be found even if only a subpart or subassemly has the AttributeSet.
If yout Need the Information for the single assembly you can check the AttributeSets of the componentdefinition.
Best Regards
Wolfgang
J_Dumont
Hi Wolfgang,
Thanks for your input. The program works well.
I was wondering if you can expand on it.
The issue I have is that if I place a structural member using Place From Content Center directly, your code shows that it was placed by FG.
Is there a way to filter this out and truly only identify those components placed by FG?
wolfgang_nickl
Hello Dumont,
sorry, I don't know a property that will tell this.
In a quick view in the local window of vba, I saw that
the AttributSet of Frame elements has two items,
while the Part from ContentCenter has only one.
But I don't know it it behaves that way ever nor
Best Regards
Wolfgang
A.Acheson
You can check this using document interests method. See this post.
Regards
Alan
