Ilogic - get hole diameter value from part within an assembly
HI,
Does anyone know how to get a hole diameter value from a part within an assembly using ilogic?
Similar to using the measure distance tool which gives you a measurement.
Cheers,
Tony
HermJan.Otterman
hello,
this is a verry general question...
the biggest problem will be to tell you iLogic/VB routine what hole needs to be measured, do you select it? or does it have a name
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Hi Hermjan,
I want to select the hole.
HermJan.Otterman
mainly from the Inventor API help:
    ' Get a feature selection from the user
    Dim oObject As Object
    oObject = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "Pick a feature")
    MsgBox("Picked: " & oObject.Name)
' if extrusion, the radius is:
  MsgBox(oObject.sidefaces.item(1).geometry.radius)
(the radius will be in centimeters!!!)
Herm Jan
Hi Hermjan,
Thanks for that. I changed the kpartfeaturefilter to kallcircularentities and message box.
SyntaxEditor Code Snippet
' Get a Hole selection from the user
    oObject = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kallcircularentities, "Pick a Hole")
    Hole_Dia = oObject.geometry.radius*2*10 'Converted to Diameter and mm
     MsgBox(Hole_Dia & "mm Diameter")
which worked better for me.
Cheers
Tony
