Inspection dim
Inspection dim
RodolfoZanni7664
Inspection dim
RodolfoZanni7664
Good morning,
with iLogic rule,how can find and read (also the label) the inspection dimension  ?
With the follow code (found on the web), i can read the values but not the label :
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSubDoc As Inventor.Document
Dim oPropSets As PropertySets
' Get active sheet
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".csv")
oWrite.WriteLine("Dim Text;Tol - Lower;Tol - Upper")
    ' Write each dimension to output file
    Dim oDrawingDim As DrawingDimension
    For Each oDrawingDim In oSheet.DrawingDimensions
        Dim sDimText As String
        sDimText = Replace(oDrawingDim.Text.Text, ",", ".")
  If oDrawingDim.IsInspectionDimension = True
  oWrite.WriteLine(sDimText & ";" & oDrawingDim.Tolerance.Lower & ";" & oDrawingDim.Tolerance.Upper)
    Next
oWrite.Close()
like......
oWrite.WriteLine( LABEL & ";" &  sDimText & ";" & oDrawingDim.Tolerance.Lower & ";" & oDrawingDim.Tolerance.Upper)
Thank’s for your help
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @RodolfoZanni7664,
You can call the GetInspectionDimensionData method on the oDrawingDim object to read the label value.
So your code could be something as below:
  Dim Label As String
  Dim Rate As String
   If ODrawingDim.IsInspectionDimension = True
     oDrawingDim.GetInspectionDimensionData(kNoInspectionBorder, Label, Rate)
     MessageBox.Show(Label, "Label Value")  'Label should contain desired string value
Let me know if this helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
RodolfoZanni7664
Thank you very much !!!!
Please, if you can and if you want, where i can find the list of method like 'GetInspectionDimensionData'.
Thank you
R.Zanni
sajith_subramanian
Autodesk Support
Autodesk Support
You can refer to the Programming/ API help file that is included with inventor for any methods available on a particular object.
(Inside Inventor click on Help -> Programming /API help to navigate to the help file). So,if you search for DrawingDimension it will give you all the methods and properties that apply to that object.
Sajith
Sajith Subramanian
RodolfoZanni7664
Great!,
thank you very much for your very fast answer !
R.Zanni
ashleyU6MWT
Hi, is it possible to modify this code to extract stacked limit dimensions rather than upper and lower tolerances?
thanks you
