Use value from paramter list
I need to use a value from multi-value paramter in a rule
If you open the attached part, open the rule: "Rule_Sliderail_Type", I've added a note/desription of what I want to happen
I need to pull the dimension from that, so that my sliderail changes diameter accordingly
HermJan.Otterman
can't yoy just do this:
SyntaxEditor Code Snippet
If Sliderail_Type = "1.5 Galvanized" Then
Feature.Color("Revolution - Sliderail - Up") = "Galvanized"
Feature.Color("Revolution - Sliderail - Down") = "Galvanized"
'USE VALUE 48.3 FROM Parameter "Sliderail_Diameter"
Sliderail_Diameter = 48.3
ElseIf Sliderail_Type = "1.5 Stainless" Then
Feature.Color("Revolution - Sliderail - Up") = "Steel - Polished"
Feature.Color("Revolution - Sliderail - Down") = "Steel - Polished"
ElseIf Sliderail_Type = "1.5 Plastic" Then
Feature.Color("Revolution - Sliderail - Up") = "Smooth - Red"
Feature.Color("Revolution - Sliderail - Down") = "Smooth - Red"
ElseIf Sliderail_Type = "2.0 Galvanized" Then
'USE VALUE 60.3 FROM Parameter "Sliderail_Diameter"
Sliderail_Diameter = 60.3
ElseIf Sliderail_Type = "2.0 Plastic" Then
iLogicVb.UpdateWhenDone = True
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Thank You
What does the following line do?
HermJan.Otterman
this line will do an Update of your model,
look in the iLogic snippest, (system), Document
Herm Jan
