Check if drawing has unsaved user edits
pball
Mentor Mentor
pball
I have a batch function that processes open drawings and it closes each drawing it processes. I'd like to check if a drawing has unsaved user edits before closing it. However checking if the status of the file is dirty isn't granular enough of a check. I noticed if you modify a part and then open its drawing, the drawing is dirty because the part changed. I'd like to ignore that situation. I only want to know when a user has edited a drawing. Inventor knows the difference, but I'm not sure if the API can access that info.
Part updated but no changes made to drawing
Drawing edited by user
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
bradeneuropeArthur
Try this:
.ActiveDocument.RequiresUpdate
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
pball
Unfortunately in my quick test .RequiresUpdate returned false for edits make to the drawing and when the model was edited and the drawing opened afterwards. So I'm not sure what updates that property is looking for.
