Check-Drawing customization
aleksei.lipatnikov
aleksei.lipatnikov
Good day all,
i have an issue with the drawing. I need to prepare the Check-Drawing, which will have all the same measurements, but they needs to be blind. (only dimension guides must stay). Any ideas of doing it all-in-one?
Right now the only way is to modify each dimension (add empty text and hide the measurement value), but there needs to be a quicker way.
Thank you.
bradeneuropeArthur
With this you can:
For VBA:
Public Sub CheckDim()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As DrawingDimension
Dim cs As DrawingDimensions
Dim sh As Sheet
Set sh = b.ActiveSheet
For Each c In sh.DrawingDimensions
c.ModelValueOverridden = True
c.HideValue = True
c.Text.FormattedText = ""
Next
End Sub
 For Ilogic you need to remove the "Set" in all lines!
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
aleksei.lipatnikov
Thank you!!
p.s. the code needed to be modified to i-Logic. (let/set remove and Sub Main)
bradeneuropeArthur
Dim sh As Sheet
 '?.FormattedText
If InStr(c.Text.Text, "Ø") Then
'MsgBox c.Text.Text
c.HideValue = True
c.Text.FormattedText = "[ Ø       ]"
Else
c.HideValue = True
c.Text.FormattedText = "[         ]"
Next
End Sub
To your question.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
